The relationship between potential energy and kinetic energy
The discussion revolves around the relationship between potential energy (PE) and kinetic energy (KE) in the context of a mass dropped from a height, specifically examining the energy transformations at the halfway point of its fall. Participants explore the theoretical underpinnings of energy conservation and the application of kinematic equations to derive the correct values for PE and KE at a given point during free fall.
  • One participant states that at halfway down a distance, the potential energy lost equals the kinetic energy gained, referencing the conservation of energy principle.
  • Another participant challenges the initial calculations, suggesting that the velocity at the halfway point is incorrectly derived and should be calculated using kinematic equations.
  • Several participants point out that the time taken to fall 1 meter is miscalculated, referencing Galilei's law of free fall to correct the assumptions made in the original problem.
  • A participant proposes a method to find the velocity at the halfway point using the correct kinematic equations, leading to a recalculation of KE and PE.
  • Another participant confirms the calculations provided by a peer, indicating that they align with the expected results based on energy conservation.
  • One participant questions the validity of the initial simpler assumptions and asks for clarification on the underlying principles of the equations used.
There is no consensus on the initial calculations presented. Participants express differing views on the correct application of kinematic equations and the assumptions made regarding time and velocity. The discussion remains unresolved regarding the initial claim about energy equivalence at the halfway point.
Participants highlight limitations in the initial problem setup, including incorrect assumptions about time and distance in free fall, and the need for accurate application of kinematic equations to derive correct values for velocity, PE, and KE.
ThievingSix
In class it was explained that at half way between a given distance Potential energy(PE) lost equals the Kinetic energy(KE) gained. OR
PE Lost = KE Gained at 1/2 the distance.
But when i do the math for it, it does not work out. What am i missing, i understand the concept but i can't prove it? And in theory it sounds correct because of the law of conservation of energy.
Here is the situation(i made it up to prove that the statement is correct).
A stationary mass is dropped from a distance of 1m and the only force that acts upon it is the Earth's gravity, it hits the ground in 1 second and its motion is along the Y axis only. Calculate PE and KE at "X".
[PLAIN]http://img854.imageshack.us/img854/3959/diagram.png
This is what i have so far,
Distance = 1m
Time = 1s
Mass = 10kg
Acceleration = 9.8 m/s/s
Initial speed = 0 m/s
Final speed = 9.8 m/s
Force = 98N(toward's the center of the earth)
Gravitational Potential energy(mass*gravity*height) = 10*9.1*1 = 98 kgms
Potential energy at rest(mass*acceleration*displacement) = 10*9.8*1 = 98 kgms
Kinetic energy at rest(1/2 Mv2) = 1/2*10*0 = 0 kgms
This is where it gets confusing,
PE at "X" = 10*9.8*0.5(half the displacement) = 49 kgms(which should be correct)
KE at "X" = 1/2*10*4.92(velocity at "X") = 120.05 kgms
Therefore PE lost [tex]\neq[/tex] KE gained at half the distance?
I've done something wrong, but what?, I've ran through this so many times i can't even see my own error.
Your velocity at point X is wrong, it should be the square root of g. You need to solve the UVAST equations for x=0.5 and then use the time taken to reach X to find your velocity at point X.
Your velocity is wrong.You probably assumed that the time it took the mass to reach the x point was 0.5sec which is not right.
There are several problems in the problem you have published. Firstly, "A stationary mass is dropped from a distance of 1m and the only force that acts upon it is the Earth's gravity, it hits the ground in 1 second and its motion is along the Y axis only. Calculate PE and KE at "X". " is wrong, because it wil not take a body 1 sec to fall 1 m.
Galilei's law of the free fall state, that s = 1/2*g*t^2. So in 1 sec the distance is s = ½*9,82*(1)^2 = 4,91m
You have to use this law to calculate the time used for falling s meters. (s =½ m )
s= ½*g*t^2. t => t= sqrt(2s/g) and then you have to insert this in v = g*t = g*sqrt(2s/g)=sqrt(2s*g), and you get, that the kinetic energi (and thereby the change in kinetic energy) is
Ekin= ½*m*v^2 =½*m*(2s*g) = m*s*g and that is exactly the change in potential energy by falling s meters.
The only numbers you have to know - to do your calculations - is s and m.
But you do not have to know the mass to prove your statement. Just use Galileis law for falling bodies, which comes out of Newton's second law F = m*a
Yes - you always need to choose the right SUVAT equation to get what you need ONLY from what you have. You must not make 'assumptions' about values unless you have calculated. This is one of the most common problems for students starting on Motion problems. :smile:
Alright this is how i got the answer, please tell me if its the right way.
I used the method Vagn suggested.
Finding velocity at "X"
v2 = u2 - (2gs)
v2 = 02 - (2*9.8*0.5)
v2 = -9.8
v = [tex]\sqrt{9.8}[/tex]
Finding KE at "X"
KE = [tex]\frac{1}{2}\times m \times v[/tex]2
KE = [tex]\frac{1}{2}\times 10 \times (\sqrt{9.8})[/tex]2
KE = 49 kgms
Therefore PE lost = KE gained at X
proper:
since you are taking it at the half way ,
D=0.5
m=10
t= 1s and half time is 1/2 s
Acc=g=9.8
final speed=the speed half way =Vf= √9.8 if time is half
PE=mgh
Ke=1/2mV2
Pe=10x10x0.5=50
Ke=1/2x10x(√9.8)2=49.92
v2 = u2 - (2gs)
v2 = -9.8
ThievingSix
Do you know where these "UVAST" equations & Galilei's law come from and why your initial, simpler, assumption is not valid?
  • · Replies 41 ·
  • · Replies 138 ·
9K
