The sound of a perfect square wave
A perfect square wave theoretically contains infinite odd harmonics, making it impossible to produce in reality. If it could be generated, it might sound similar to a clarinet rather than harsh or buzzy. Human hearing is limited to about 20 kHz, meaning differences between a perfect square wave and one with higher harmonics removed would be inaudible. Additionally, air may restrict the ramp rates of generated square waves. Some discussions suggest that ultrasound, when transmitted directly to the skull, produces unique sounds that differ from conventional musical notes.
Mohd Abdullah
Hey guys,
It is stated that a 100% perfect square shaped wave have infinite odd harmonics and it is impossible to produced theoretically. But, assuming if a perfect square wave is produced, what would it sound like? I remember someone said it in Youtube it would actually sound like a clarinet instead sounding harsh and buzzy.
It's a common alarm tone, and you can hear one yourself on the Wikipedia article on square waves.
Human ears can't hear anything above about 20 kHz*, so you couldn't hear the difference between a "perfect" square wave and one with harmonics above 20 kHz removed.
*That's for healthy young ears. The limit could be much lower for older ears.
Likes Mohd Abdullah
In addition to the limitation of human hearing, wouldn't the air also limit the ramp rates on something close to a generated square wave?
One fun thing you can try if you have access to Mathematica is to find the Fourier series for a square wave and then use the 'Play' function. You can add successive harmonics and try each one and then experience it for yourself.
Thanks for the response. But recently I hear people saying that ultrasound can be heard if it is fed directly to the skull, I think it doesn't sound like any of the musical notes for example, the highest note of the piano. I think it sounds weird and unique. Thoughts?
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
