The work done by an adiabatic process?
The discussion focuses on the work done by an adiabatic process, specifically using the formula W=(C/1-y)(Vf^(1-y)-Vi^(1-y)), where y is defined as Cp/Cv. The variable C is clarified to represent a constant K, typically expressed as PV^γ = K. Participants confirm that during an adiabatic process, the relationship P1V1^γ = P2V2^γ holds, and the ideal gas law cannot be applied in the same manner due to the nature of adiabatic conditions.
  • Understanding of thermodynamic processes, specifically adiabatic processes.
  • Familiarity with the ideal gas law (PV=nRT).
  • Knowledge of specific heat capacities (Cp and Cv).
  • Basic algebra and manipulation of equations involving exponents.
  • Study the derivation and applications of the adiabatic process equations.
  • Learn about the differences between reversible and irreversible adiabatic processes.
  • Explore the implications of the first law of thermodynamics in adiabatic conditions.
  • Investigate the relationship between temperature, pressure, and volume in adiabatic processes using real gas behavior.
Students of thermodynamics, mechanical engineers, and anyone studying the principles of heat transfer and energy conservation in adiabatic processes.
JustinLiang
On my formula sheet I have this:
y=Cp/Cv
I am confused about what the C in C/1-y stands for. My textbook does not even have this formula and I realized that C is not Cp or Cv...
y=Cp/Cv
The C is usually expressed as K as in: PV^\gamma = K. So it can be written:
W = \frac{P_iV_i^\gamma}{1-\gamma}(V_f^{1-\gamma} - V_i^{1-\gamma})
AM
AM
Ahh ok thanks! But why is it Vi and Pi, why not Vf and Pf? Is there a reason?
You can make it Vf and Pf or any V, P during the adiabatic process if you like:
P_iV_i^\gamma = P_fV_f^\gamma = PV^\gamma = K = \text{ constant}
AM
AM
Okay, so for an adiabatic process, we cannot use the typical ideal gas law P1V1=P2V2 right?
What about PV/T=PV/T?
If PV=nRT and PV = constant then T would be constant (assuming n is constant). But in an adiabatic process that does work this cannot be the case: dQ = 0 -> dU = -dW where dW is the work done by the gas. So P1V1 ≠ P2V2.
In a reversible adiabatic process involving an ideal gas, the condition PV^\gamma = K holds. But so does PV=nRT. Substituting P = nRT/V the adiabatic condition becomes:
PV^\gamma = nRTV^{\gamma-1} = K
and since n and R are constant (assuming no change in the amount of gas) we have:
TV^{\gamma-1} = K/nR = K' = \text{constant} and
PV/T = nR = \text{constant}
AM
  • · Replies 19 ·
  • · Replies 39 ·
