What Implications Arise from Modifying the Division Theorem in Number Theory?
Modifying the division theorem in number theory introduces an alternative definition for the quotient and remainder, which can lead to confusion and inconsistency with established proofs. The standard division theorem, expressed as a = bq + r, is preferred because it aligns with the well-ordering principle and supports rigorous mathematical proofs. The new definitions, while theoretically valid, complicate congruence results and arithmetic operations that are naturally suited to the original formulation. The discussion emphasizes the importance of adhering to established definitions for clarity and consistency in mathematical discourse. Overall, the implications of modifying the division theorem suggest potential complications in understanding and applying number theory concepts.
Kartik.
Well the standard division theorem says,
a = bq +r
where,
0 <= r < b
after that we were introduced with r = b - r\acute{}
r\acute{} having the same domain as that of r
after that the theorem changes to
a = b(q+1) - r\acute{}
Solving it with r\acute{}= b-r, gives us the standard equation, but what does it imply?
also two conditions in r and r\acute{} where given -
r>=1/2b and r\acute{}<=1/2b
and then defining Q and Ra = bQ +R where |R| <=1/2b
What does all this mean?
Examples, please?
Mathematics news on Phys.org
Hey Kartik.
It just means you have a different definition for the quotient and the remainder.
It's better to use the original definition, and the reason for this is that all of the rigorous proofs are based on what is known as the well ordering principle and for the normal definition that is used, the proofs are standardized.
The other thing is that the natural definition of the modulus makes more sense when its defined with the normal bq + r instead of your own, because all the congruence results and arithmetic are naturally suited to this definition.
Is there any reason why you wish to use your definition over the standard one?
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
