Thermal Expansion-how much has the ocean expanded
  • Thread starter Thread starter endurance12
    Ocean Thermal
The ocean's average temperature has increased by approximately 0.375°C over the last century, prompting discussions on its volumetric expansion. The coefficient of volume expansion for water is 207 x 10^-6 per °C, which leads to calculations for the change in volume due to temperature rise. A mistake was identified in the calculation process, particularly in the application of the linear coefficient, which should not involve division by three when estimating volumetric changes. The correct approach requires directly applying the volumetric expansion coefficient to determine the percentage increase in volume. Accurate calculations are essential to understand the implications of thermal expansion on ocean levels.
endurance12
The ocean’s average temperature has risen by approx 0.375°C over the century. Use this value to estimate by how much the ocean water might have expanded in items of percentage increase.
This is what i started doing but I do not think this is right.
Coefficient of Cubical Thermal Expansion (Y)= change in volume (dv)/ Initial volume (v) * change in temp (dt)
Coefficient of volume expansion of water= 207*10^-6 per deg C
Linear coefficient = 1/3 cubical coefficient
=1/3*207*10^-6
= 6.9*10^-6%
But i am not getting the right answer I do not think. Can you please help me?
Does the question ask for a percentage increase in depth (linear) or volume (cubic)?
i believe volume
=1/3*207*10^-6
If you think the question is asking for volumetric expansion, why divide by 3?
= 6.9*10^-6%
That's off by 3 orders of magnitude. Try the last step again.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
