Thermal Expansion of brass rod
The discussion focuses on calculating the thermal expansion of a brass rod when measured with a steel tape at varying temperatures. The coefficient of linear expansion for brass is 19e-6, while for steel, it is 11e-6. The student correctly applies the formula ΔL = a * L * ΔT, ensuring to use a negative value for ΔL due to the decrease in temperature from 20.0°C to -18.0°C. This approach accurately determines the adjusted length of the brass rod under the specified conditions.
  • Understanding of thermal expansion concepts
  • Familiarity with the coefficients of linear expansion for materials
  • Proficiency in algebraic manipulation of equations
  • Basic knowledge of temperature measurement and conversion
  • Research the thermal expansion coefficients of other materials
  • Learn about the effects of temperature on measurement accuracy
  • Explore applications of thermal expansion in engineering and manufacturing
  • Study the implications of thermal expansion in real-world scenarios, such as bridge construction
Students studying physics, engineers involved in material science, and professionals working with temperature-sensitive measurements will benefit from this discussion.
lackos
A student measures the length of a brass rod with a steel tape at 20.0°C. The reading is 80.00 cm. What will the tape indicate for the length of the rod when the rod and the tape are at each of the following temperatures?
a) -18.0°C
(delta)L=a*L*(delta)T.where a for brass is 19e-6, and steel is 11e-6
i sarted by finding the change in the increment of a cm on the steel tape using the the above equation and then finding the expansion for a cm of brass at the temperature. multipplied it by the original measurement, then added the resulting value to the measuremnt. however I am not sure if this is right
Yes that would be correct. Just make sure your value for ΔL is negative, since your change in temperature is negative.
10K
