Thermal expansion of liquid in a tube
The discussion focuses on calculating the new height of liquid in a cylindrical glass tube due to thermal expansion. The key equations involve the volume thermal expansion coefficient (β) of the liquid and the linear thermal expansion coefficient (α) of the tube. The absolute height of the liquid is derived using the equation $$h_1=\frac{1+\beta \Delta T}{1+2 \alpha \Delta T}h_0$$, which accounts for both the liquid's volume expansion and the tube's area expansion. The participants clarify the distinction between absolute and relative height changes, ensuring a comprehensive understanding of thermal expansion effects.
  • Understanding of thermal expansion coefficients (α and β)
  • Familiarity with the concepts of volume and area expansion
  • Basic knowledge of algebraic manipulation of equations
  • Ability to apply thermal expansion equations in practical scenarios
  • Study the derivation of thermal expansion equations in detail
  • Explore applications of thermal expansion in engineering contexts
  • Learn about the effects of temperature changes on different materials
  • Investigate the implications of thermal expansion in fluid dynamics
Students in physics or engineering, educators teaching thermal dynamics, and professionals involved in material science or mechanical engineering will benefit from this discussion.
Soren4
A cylindrical glass tube (linear thermal expansion coefficient ##\alpha##) contains liquid (volume thermal expansion coefficient ##\beta##). The height of the tube is ##h_{t,0}## and the height of the liquid inside of it is ##h_{l,0}##. If the temperature changes of an amount ##\Delta T## what is the new height of the liquid? If the cylindrical tube is provided of a measuring scale, what is the new height of liquid measured from the scale? Do not neglet any thermal expansion.
Thermal expansion coefficients
I get a bit confuse in considering all the expansions. The relation I would use is $$\frac{\Delta V}{V}\approx\frac{\Delta h}{h} +\frac{\Delta A}{A}$$
  • To find the new "absolute" height of the liquid I would simply consider the change in volume ##\Delta V_{l}=V_{l,0} \beta \Delta T##, and then the change in the area of the cylinder ##\Delta A_{t}=A_{t,0} 2 \alpha \Delta T##. Then I would write
$$\frac{\Delta h_{l}}{h_{l,0}} =\frac{\Delta V_{l}}{V_{l,0}}+ \frac{\Delta A_{t}}{A_{t,0}}=(\beta-2\alpha) \Delta T$$
So actually in this case I did not consider the change in height of the tube, since, what is asked is simply the (absolute) change in height of the liquid.​
  • While, to get the new height of liquid "relative to the tube" I would consider the "relative change in volume" $$\Delta V_{l,relative}=\Delta V_{l}-\Delta V_{t}=(V_{l,0} \beta- V_{t,0} 3\alpha)\Delta T$$
Here is my main doubt: does this "relative" change already takes into account the fact that the area of the tube changes and that the height of the tube changes? If so, considering this "relative change" I can write​
$$\frac{\Delta h_{l,relative}}{h_{l,0}}= \frac{\Delta V_{l,relative}}{V_{l,0}}$$
And get the new height relative to the tube, but I'm not convinced about this last equation I wrote.Are these two processes correct or are there any mistakes (conceptual or of other kind) ?
Hey Soren4,
The absolute looks OK.
Still thinking about the relative equation.
But as a hint, you have the absolute height of the liquid.
You can determine the absolute height of the marking on the tube.
Does your equation confirm the relative change in height tube/liquid?By the way, do you have an understanding about how
say, the equation of ΔV/V that you have listed comes about
ie from assuming small changes in temperature
linear ( 1 + α )
planar ( 1 + α ) ( 1 + α )
volumetric ( 1 + α )( 1 + α )( 1 + α )
Soren4,
For the volumes of liquid before and after changing T we have $$V_0 = h_0A_0$$ and $$V_1=h_1A_1$$ The second equation can be rewritten as
$$(V_0+\Delta V)=(h_0+\Delta h)(A_0+\Delta A)$$
$$V_0\left ( 1+\frac{\Delta V}{V_0} \right )=h_0A_0\left ( 1+\frac{\Delta h}{h_0} \right )\left ( 1+\frac{\Delta A}{A_0} \right )$$
$$1+\frac{\Delta h}{h_0}=\frac{1+\frac{\Delta V}{V_0}}{1+\frac{\Delta A}{A_0}}=\frac{1+\beta \Delta T}{1+2 \alpha \Delta T}$$
The new height
You can use the same approach in the second part of your problem.
  • · Replies 33 ·
