- #1
SSJVegetto
- 16
- 0
Assume a two-energy-level system with energetic separation between the two levels of 10000 cm-1 (as you can easily see, λ = 1 μm equals 1/λ = 10000 cm-1, and E ∝ 1/λ, i.e. the unit [cm-1] defines an energy).
a) What is the thermal population in the upper level?
b) If you pump the system with a very intense laser, how much will the
population of the upper level increase? Explain the result!
c) Under these conditions, can you achieve lasing? Explain the answer!
[tex]k\ =\ 1.3806503(24)\ \times\ 10^{-23}\ J\ K^{-1}[/tex]
[tex]h\ =\ 6.62606876(52)\ \times\ 10^{-34}\ J\ s[/tex]
[tex]\frac{N_{2}}{N_{1}}=\frac{g_{2}}{g_{1}}.e^{-(E_{2}-E_{1})/kT}[/tex]
a. I'm assuming the degeneracy can be taken to be 1 for both? And now i use the equation given above to solve this problem and i get [tex]\frac{N_{2}}{N_{1}}=0.61[/tex] where i used for the energy difference [tex]E_{2}-E_{1}=\Delta E=\frac{hc}{\Delta\lambda}[/tex]. Where i used [tex]\Delta\lambda=10000 cm^{-1}[/tex] I am wondering if i got the energy right.
b. I really need some help with this one i just don't know how to answer this one. c. I don't know how to answer this i think when you can achieve population inversion the laser should be able to start lasing. But whether to tell if it can achieve that yes or no i don't know how to answer that and would appreciate some help.
Bob
