Do Neutrons Emit Infrared Radiation at Room Temperature?
All bodies with a temperature emit electromagnetic radiation due to the thermal motion of their atoms. Neutrons, despite being neutral particles, can emit thermal radiation because they possess a nonzero magnetic dipole moment and are made of fractionally-charged quarks. Neutrons at room temperature would indeed emit thermal radiation, as evidenced by neutron stars exhibiting blackbody spectra. Additionally, neutrons can emit electrons through beta decay, indicating their complex interactions with electromagnetic fields. The emission of thermal energy occurs as neutrons transition to a more stable, lower energy state.
jjschwartz1
All bodies with a temperature emit electromagnetic radiation also known as thermal radiation or blackbody radiation. If I understand it correctly, the origin of this is the thermal motion (acceleration) of the atoms and their included positive and negative charges leads to EM radiation.
Would a bunch of neutrons at, say, room temperature emit infrared radiation? I would think they would as "all bodies with a positive temperature emit electromagnetic radiation". But I'm at a loss to explain why.
Science news on Phys.org
A bunch of neutrons at a finite temperature T would emit thermal radiation. We have even observed such objects: neutron stars. I believe their spectra are roughly blackbody, but of course there are many interesting effects that play into the precise form of the spectrum.
Are you confused because a neutral particle shouldn't couple to the EM field? Remember, though, that the neutron has a nonzero magnetic dipole moment, and it is actually composed of fractionally-charged quarks. So it can couple to the EM field.
Not only do neutrons emit electromagnetic energy [thermal energy] they actually emit electrons! That's called beta decay. This suggests 'a neutron is a proton plus an electron combined' which is likely an over simplification that started with Rutherford.
edit: found a brief description here:
http://en.wikipedia.org/wiki/Neutron#Intrinsic_properties
You can also tell a neutron has some EM character [electron like] because it has a magnetic dipole moment.
Forgot to say: If anything emits thermal energy, its because the emitter is not in the most stable, low energy state...so it's likely that as the neutron constitutents emit EM energy they settle to a lower energy configuration.
Thread 'Thermo Hydrodynamic Effect'
Vídeo: The footage was filmed in real time. The rotor takes advantage of the thermal agitation of the water. The agitation is uniform, so the resultant is zero. When the aluminum cylinders containing frozen water are immersed in the water, about 30% of their surface is in contact with the water, and the rest is thermally insulated by styrofoam. This creates an imbalance in the agitation: the cold side of the water "shrinks," so that the hot side pushes the cylinders toward the cold...
