Thermodynamic Exercise: Adiabatic Cylinder with Double Chamber and Piston
The discussion revolves around a thermodynamic exercise involving an adiabatic cylinder with a double chamber separated by a piston. Participants explore the implications of turning on an electrical resistance in one chamber, leading to a new thermodynamic equilibrium. The focus includes energy balances, work done, and heat transfer in the system.
  • Roberto questions the correct equations for energy balance in the system, presenting several formulations for the total energy and chamber-specific balances.
  • AM suggests that the electrical energy converts entirely into heat, questioning whether work is done during the process and the implications of heat flow between chambers.
  • Some participants discuss the sign conventions in the first law of thermodynamics, noting that different texts may present varying conventions that can lead to confusion.
  • Roberto expresses confusion regarding the relationship between work done and heat flow, particularly in the context of the adiabatic nature of the system.
  • Participants explore the implications of the system being in static equilibrium before the resistance is turned on, and how this affects the calculations of internal energy and work.
  • Roberto shares a detailed example involving specific values for gases and calculations related to the system's behavior, seeking feedback on the correctness of his approach.
Participants do not reach a consensus on the correct formulation of the energy balances or the implications of the first law of thermodynamics in this context. Multiple competing views on sign conventions and the treatment of work and heat transfer remain evident throughout the discussion.
There are unresolved issues regarding assumptions about heat transfer between chambers, the definitions of work done, and the specific conditions under which the first law is applied. The discussion reflects a variety of interpretations of the thermodynamic principles involved.
This discussion may be useful for engineering students, educators, and practitioners interested in thermodynamics, particularly those dealing with adiabatic processes and energy balance equations.
CVB
Hello, my name is Roberto and I am engineering student from Spain. I am a new member in the forum and I don´t know if this is the right site to present me but I want to use this moment to say hello to the comunity.
I have a doubt with a thermodinamic exercise.I have an adiabatic cylinder with double chamber separated by a piston diatermano. In the chamber of the left there is a resistance initially turned off and the system is in thermodynamic equilibrium. When turn on the resistance the piston moves to reach a new equilibrium.My doubt is what are the right ecuations:
-Total energy balance [tex]\Delta U_ {total}=-W_ {elec}[/tex]
-A chamber [tex]\Delta U_A=Q-W_{exp}-W_{elec}[/tex] or [tex]\Delta U_A=-W_{exp}-W_{elec}[/tex]
-B chamber [tex]\Delta U_B=Q-W_{exp}[/tex] or [tex]\Delta U_B=-W_{exp}[/tex]
Thank you very much and I sorry if something is wrong.
Science news on Phys.org
Welcome to PF!
I am not sure what W_exp is.
The electrical energy is all turned into heat flow. This heat flow is initially into the left side:
[tex]Q_{A} = W_{elec}[/tex]
But some of the heat then flows into the right side through the piston. The question is whether there is any work done. If there is no work done, then [itex]\Delta U = Q = W_{elec}[/itex] (I am not sure why you have minus signs there).
Is there any work done by the gas on either side?
AM
Don't you think the electric heater in the left chamber heats the gas inside which expands, pushing the piston into the right chamber compressing the gas in the right chamber until equilibrium is again reached?
Hello Roberto
I think your confusion arises because of sign convention. This is a very common confusion.
The first law is normally stated
[tex]\Delta[/tex]U = q - w
q is the heat input to the system - counted positive
w is the work done by the system - counted positive
So q is energy in and w is energy out.
Edit
Some books use
[tex]\Delta[/tex]U = q + w
Where w is negative for work done by the system (energy out) and positive for work done on the system (energy in)
This leads to the same result, but the different sign conventions can be confusing.
Quite reasonably putting energy in increases the internal energy
Taking energy out decreases it.
That is why the equation is written with a minus sign.
So in your case the electrically generated heat in is positive and the expansion work done by the left chamber is also positive.
So in the left chamber
[tex]\Delta[/tex]U = qelectrical - wexpansion
In the right chamber
There is no heat input but work is done on the system so is negative (= minus work done by the system)
So [tex]\Delta[/tex]U = 0 - (-wcompression)
Hope this helps
go well
First, I want to say thank you for your quick reply, I am very grateful. I am very confused because I understand [tex]Q=W_{elec}[/tex] but I am going to upload a book where [tex]W_{out}=W_{exp}+W_{elec}[/tex] and the first law is [tex]\Delta U=Q-W_{out}[/tex] you can see example 4.16.
Than you
My Spanish is not that good, but I presume you mean example 4.6, PDF pages 85 to 86?
As far as I can make out they have stated the same thing I did, but they have worked out fully the equations using the fact that the work done in chamber A = - work done in chamber B.
Like me thay have assumed that no heat is transferred from chamber A to chamber B, only work.
What do do not understand about their working?
Hello,thank you for your reply. Yes the question is that in the total balance before turn on the resistance [tex]\Delta U = -W_{elec}[/tex] because the system is adiabatic and Q=0. But to calculate Q in left chamber after turn on the resistance would be [tex]Q=N C_v (T_f-T_i)+W_{expansion}+W_{elec}[/tex]
Thank you
Before electricity is supplied to the resistance the system is in static equilibrium: [itex]\Delta Q = \Delta U = W = 0[/itex]
Not quite:
[tex]Q=N C_v (T_f-T_i) + W_{expansion} = W_{elec}[/tex]
if you ignore the heat flow from the left to the right side.
On the right side, without any heat flow from the left, Q = 0. What is the relationship between the work done by the right side and the work done by the left side? What does that tell you about the change in internal energy on the right side?
AM
Hello Andrew,thank you for your reply.It`s right that before electricity is supplied to the resistance the system is in static equilibrium: [itex]\Delta Q = \Delta U = W = 0[/itex]
I wanted to say [itex]\Delta U_{total} = -W_{elec}[/itex].
If you don´t mind I`m going to write all exercise and like I solve it.
Have a rigid and thermally insulated tank having a diatermano piston that divides in 2 separate parts. Part A contains oxygen and inside there is a resistance connected to 220 v which supplies a electric current of 3 amperes. The other part B contains helium. Initially the system is in thermal equilibrium.Oxygen mass is 3 kg and 6 bar pressure.Helium mass is 0.5 kg, their pressure 2 bar and 100 º C. Temp. We turn on the resistance for 3 minutes while freeing the piston.In B there is a polytropic process. The gases are perfect.
Answering a) P, T, V start and end in A and B
b) Flow of heat and expansion work exchanged by both chambers
a) First I calculate moles in A (93,75 mol) and in B (124,91 mol).
Like the system is in thermal equilibrium [itex]T_A=T_B[/itex] then by [itex]PV=NRT[/itex] I calculate [itex]V_A=477,9 Litres[/itex] and [itex]V_B= 1910.24 Litres[/itex] Now I calculate
[tex]W_{elec}= P= I . v= 220 x 3 = 660 W=0,660 Kw x 180 sec = 118,8 Kj[/tex]
Then [itex]\Delta U_{total} = -W_{elec}\rightarrow[/itex] Then [tex]m_A Cv_A(T_f-T_i)+m_B Cv_B (T_f-T_i)= -W_{elec}[/tex] I calculate [itex]T_f= 406,88ºK[/itex]
To Calculate final pressure : [itex]V_A+V_B= V_T[/itex] I calculate [itex]V_T=477,9+1910,24=2388,14 Litres[/itex]
Like the total volume is constant
[itex]V_T= \frac{N_A . R. T_f}{P_f}+ \frac{N_B .R .T_f}{P_f}[/itex]
[tex]2388,14 = 93,75 x 0,082 x 406,88/P_f + 124,91 x 0,082 x 406,88/P_f[/tex]
Then [tex]P_f= 3,05 Bar[/tex] and Final volume in B is [tex]V_B = 124,91 x 8,3143 x 406,88/305 = 1385,44 litres[/tex]
And Final volume in A is [tex]V_A =2388,14-1385,44 = 1002,7 litres[/tex]
b)To calculate heat and expansion work flow
[tex]\Delta U_B=Q-W_{expansion}[/tex]
we know is a polytropic process and we need calculate polytropic index
[tex]n = \frac{Ln (P_B/P_A)}{Ln (V_B/V_A)}=1,31[/tex]
After [tex]W_{exp}= \frac{P_2 . V_2-P_1 . V_1}{ 1-n } = -381,69 Kj[/tex]
I`m sorry I have problems with Latex code and I don`t know why.I`m going to finish post by attachment.Thank you.[tex]\frac{}{}[/tex]
Hello again, here is the exercise,do you think is ok?. I ´m sorry to send it by attachment. I will try to solve my Latex problem.Thank you for your help.
14K
