Thermodynamics homework: Water heated in a sealed container
The discussion revolves around a thermodynamics homework problem involving the heating of water in a sealed container. Participants are tasked with calculating the required power of an electric heater to maintain a constant vapor mass flow rate while considering the thermodynamic properties of the water and the system's constraints.
  • Homework-related
  • One participant presents the problem statement and initial conditions, including mass, pressure, and specific enthalpy values.
  • Another participant suggests using an enthalpy balance to estimate the heater power, proposing a rough calculation based on the mass flow rate and enthalpy of vapor.
  • Concerns are raised about the clarity of the equations presented, with a request for LaTeX formatting and clarification on the notation used for thermodynamic properties.
  • A participant explains the significance of the prime and double prime values, indicating they represent properties of liquid and vapor phases, respectively.
  • There is an exploration of different approaches to the problem, including mass and energy balances, with attempts to derive relationships between the variables involved.
  • Some participants express confusion regarding the consistency of the power calculation across different time intervals, suggesting that the power should remain constant for a steady mass flow rate.
  • Further discussion includes the implications of the tank volume being constant and how it affects the mass balance of liquid and vapor in the container.
  • Participants attempt to derive equations for the rates of change of mass for both liquid and vapor phases, leading to a complex interplay of variables.
Participants do not reach a consensus on the correct approach or solution to the problem. Multiple competing views and methods are presented, with ongoing confusion and refinement of ideas.
Participants note limitations in the problem statement, including potential missing assumptions about pressure constancy and the need for clearer definitions of variables. The complexity of the equations and the need for consistent units are also highlighted.
This discussion may be useful for students studying thermodynamics, particularly those dealing with energy balances in closed systems and the application of enthalpy in practical scenarios.
erde
Hello, i have the following assignment due for monday and i have truly no idea how to tackle it, i have already tried it many times but all my results have been wrong. the problem is as follows.
inside a sealed container is an amount of water: mass=90.26 kg; pressure 9.1842 bar; x=0.00051 ;
h´=745.14[kJ/kg]; h= 746.17 [kJ/kg]; h´´=2773.6[kJ/kg];
v´=0.001[m^3/kg]; v= 0.0011[m^3/kg] ; v´´=0.21338[m^3/kg];
u´=744.22[kJ/kg] ; u=745.15[kJ/kg]; u´´=2580.12[kJ/kg]
the container is heated using an electric heat source with P=? (im looking for this)
the container has an entry and an exit valve, both closed.
1) the exit valve is opened; now calculate the heater power P=? in kW required for a constant exit vapor mass(dm/dt) of 0.1[kg/s] while maintaining h´´=2773.6[kJ/kg]
(du/dt)=(du/dM) * (dM/dt)
take into account that the liquid water level inside the container sinks
only vapor h´´ leaves the container
M=90,26 kg; m=0,1 kg/s
deltaU=-deltaM*h+P*t |d()/dt
dm/dt * u+ du/dt *m = -m*h+ P
dm/dt* u + du/dt*m= -m * h +P |m=const-> dm/dt=0
du/dt * m=-m*h + P |du/dt= du/dM * dM/dt
du/dM * dM/dt*m= -m*h + P
du * (m^2)/dM= -m*h +P |* dM
integrate (m^2 * du ](0 to-> u) =-h* Integrate (m*dm] (0 to -> M) + integrate (P dM)(0 to->M)
(m^2)*u = -m*M + M*P
m*u= -m +P
[kJ]= [kg/s] + [kJ/s] --> so wrong
Hello erde, :welcome:
Pressure is high :smile: , so I won't pester you with guidelines and such, that'll come later. But making the 1. problem statement a bit more explicit would be helpful for you too (not just units, but also explaining the variables -- never mind, I can guess). And 2. the relevant equations need a few more relationships; so that all variables you need for 3. the attempt at solution actually appear. Plus the kind of physics law(s) you need to work this out.
No concrete help so far. But my first line of inquiry here (is this step 1 in a multi-part exercise?) would be if I can apply an enthalpy balance. Grossly 0.1 [kg/s] * 2773.6[kJ/kg] = 277.36 [kW] but I suppose the enthalpy of the vessel contents also changes a little bit.
On another note: I am surprised by the 1-digit accuracy of v and dm/dt appearing aside 5 or 6 digit others, but that's an issue for the exercise composer.
It's hard to read your equations. Any chance of your using LaTex (tutorial provided in Help from INFO drop down menu). In your heat balance, you should have a -dm/dt in front of the h on the right hand side, rather than a -m. Also, can you please provide the exact statement of the problem. Also, what do the primes and double primes on the properties signify.
the prime values are the values for liquid water at the given pressure and the double prime are the values for the vapor at the given pressure, x is the amount of vapor.
also for relevant equations, i tried to use U2-U1=-ΔM *h + P*t
ΔM being the amount of water that leaves the container in this case 0.1 kg/s, h being equal to h´´ as only vapor leaves the container, P the heating power and t the time
for U is the equation U=M*u; U1 is M1*u1 which are the mass before anything happens 90.26kg and u for the given pressure and x, which is u=745.15[kJ/kg]
and U2 would be the mass and the u sometime after.
i tried solving it again without integrals using the following:
U2-U1=-m*t*h´´ + P*t | m being the the per second amount 0.1kg/s as delta M is the difference between both masses M1 and M2
M2*u2 - M1*u1 = -m*t*h´´ + P*t |now with following changes: M2=M1-m*t
(M1-m*t)*u2 - M1*u1 = -m*t*h´´ + P*t |now for u2: u2= u´+x2*(u´´-u´); x2= (v2-v´)/(v´´-v´) ; v2=V/(M2)=> v2=V/(M1-m*t) the container Volume V is given with 0.1m^3
(M1-m*t)* [u´+ (V/(M1-m*t)-v´)/(v´´-v´))*(u´´-u´)]- M1*u1 = -m*t*h´´ + P*t
this new equation should give M2, u2 and therefore U2 together with ΔM values depending of the time t. the thing is P should be constant no matter how much time has passed since the vapor started leaving the container as we are looking for P for which m is constant so the value of P should NOT change for any values of t but when trying it out i get different P values for every different t values so this method is also wrong :(
the exact statement of the question is: what value P has to have the electric heater H so that a constant vapor mass of 0.1kg/s leaves the container with h=2773.6 (tip du/dt=du/dm * dm/dt) take into account that during this exit process because of the continuous vapor formation the liquid water level sinks.
this question is the last one in a 45 points exercise and gives alone 18 out of 45 points(the exercise comes from an old exam for which 1 point is equal to 1 minute being a 90 points exam with a duration of 90 minutes)
i thought of doing the problem using P=m*(h´´-h´) with P the amount of energy needed to get 0.1kg/s of water from h´to h´´ but i don't see how the given help du/dt= du/dM * dM/dt helps here. also it isn't stated anywhere that the pressure inside the container remains constant, but the only pressure at which water has the h´´ value of 2773.6[kJ/kg] is the given one so the pressure has to remain constant in order for the water vapor to have that enthalpy. so the equation P=m*(h´´-h) would only take into account the energy need to generate the leaving vapor but it would not take into account the energy needed to increase u of the remaining water inside the container in order to maintain the pressure. so P > m*(h´´-h´)
You are correct that the pressure and temperature don't change.
Let ##m_L## = mass of liquid in tank
##m_V## = mass of vapor in tank
##v_V## = specific volume of vapor in tank
##v_L## = specific volume of liquid in tank
##\dot{m}## = (constant) rate of mass exiting the tank
In terms of these parameters, what is the mass balance on the tank contents? In terms of these parameters, what is the volume V of the tank at any time? Is the volume V of the tank changing with time? From this information, what is ##dm_V/dt## in terms of ##\dot{m}##, ##v_V##, and ##v_L##? In terms of these parameters, what is ##dm_L/dt## in terms of ##\dot{m}##, ##v_V##, and ##v_L##?
volumen of the tank is V=0.1m3=const
Mass at the start would be mV,1=m1*x; mL,1=m1*(1-x)
the total Mass in the tank would be m(t)=m1- ## \dot m ## * t
mV(t)=mV,1 - ## \dot m ## * t + ## \frac {P}{(h´´-h´)} ## *t
mL(t)=mL,1 -## \frac {P}{(h´´-h´)} ## *t
dmV/dt>0
dmL/dt<0
vL=const
vV=const
dmV/dt=-## \dot m ## + ## \frac {P}{(h´´-h´)} ##
dmL/dt=-## \frac {P}{(h´´-h´)} ##
im really puzzled how to find dm/dt in terms of ## \dot m ## vV and vL
mL*vL + mV*vV=0.1m3
dmV/dt>0
dmL/dt<0
vL=const
vV=const
mL*vL + mV*vV=0.1m3
First of all, the volume is not 0.1 m^3.
Mass Balance: $$\frac{dm_L}{dt}+\frac{m_V}{dt}=-\dot{m}\tag{1}$$
Tank Volume: $$m_Lv_L+m_Vv_V=V=const$$
So, $$v_L\frac{dm_L}{dt}+ v_V\frac{dm_V}{dt}=0\tag{2}$$
So, using only Eqns. 1 and 2, what do you get for ##dm_L/dt## and ##dm_V/dt## in terms of ##\dot{m}##, ##v_V##, and ##v_L##? Using this same set of variables (and ##u_L##, ##u_V##, ##h_V##, and P) what is the transient heat balance on the tank?
1) dmL/dt=- ## \dot m ## -dmv/dt
2) in 1) dmL/dt=- ## \dot m ## + vL/vV*dmL/dt
## \dot m ##= vL/vV*dmL/dt - dmL/dt
## \dot m ##=[vL/vV-1] dmL/dt
-> dmL/dt=## \dot m ## / ([vL/vV]-1)
-> dmV/dt=## \dot m ## / ([vV/vL] -1)
dmL/dt* uL + dmV/dt * uV = -## \dot m ## *hV +P
## \frac {\dot m} { ( \frac {v_L}{v_V }-1) }*u_L + \frac {\dot m} { ( \frac {v_V}{v_L }-1) }*u_V = - \dot m *h_V + P ##
i tried solving this equation for P in my calculator and got P=18.48 kW which seems a bit too low as the energy required only for ##\dot m## is P=##\dot m *(h´_V - h_L)
Excellent! Now, solve for P, simplifying mathemtaically the resulting relationship as much as you can.
Incidentally, in LaTex, you don't need to use *'s to indicate multiplication.
i tried solving this equation for P in my calculator and got ##P=18.48 kW## which seems a bit too low as the energy required only for ##\dot m## is ## P=\dot m(h_V - h_L)=202.846 kW ## is that really the end result? also we didnt use the tip that ## \frac {du} {dt}= \frac {du}{dm} \frac {dm}{dt}##
I simplified the final result by using $$u_L=h_L-pv_L$$ and $$u_V=h_V-pv_V$$ to finally obtain: $$P=\dot{m}(h_V-h_L)\frac{v_V}{(v_V-v_L)}$$That's certainly a little greater than ## P=\dot m(h_V - h_L)##.
Regarding the hint, I thought it was goofy, and didn't expect it to be useful. I never would have given such a hint.
thank you a whole lot, i have tried again and got ## 203.8 kW## which is indeed a little more. thank you a lot for your help!
There is another (even simpler) method of solving this problem that doesn't even directly involve applying the energy balance. The rate at which liquid water is being vaporized in the tank is equal to ##\left(-\frac{dm_L}{dt}\right)=\dot{m}\frac{v_V}{v_V-v_L}##. The electric heat source must be supplying the heat of vaporization. So, $$P=\left(-\frac{dm_L}{dt}\right)(h_V-h_L)=\dot{m}(h_V-h_L)\frac{v_V}{v_V-v_L}$$
  • · Replies 27 ·
12K
9K
