FireStorm000 said:
It's impressive the range of designs you guys have pointed out. I hadn't really considered jet engines since I was mainly considering extracting thermal energy from a fluid, rather than adding it, but in hindsight, I suppose aircraft engines are relevant.
It's not clear what you mean here. For a steam turbine, the working fluid (water) absorbs the heat of combustion of fuel in a boiler, which converts liquid water to steam. The turbine extracts heat energy from the steam and turns that into work. This is an external combustion arrangement.
In a gas turbine, there are three key components: 1. a compressor to raise the pressure of the combustion air, 2. a combustion section where fuel is mixed with the compressed air and burned, generating hot exhaust gasses, and 3. the actual turbine section, where the heat energy of the combustion gasses drives a turbine.
In aircraft gas turbines, the work produced by the turbine is used to drive the compressor. The rest of the heat energy of the hot gasses is turned into thrust by passing these gasses through a nozzle as they exit the turbine.
Both turbines extract work from a fluid: a steam turbine uses steam produced by burning a fuel, a gas turbine uses the hot gasses from burning fuel directly, without the use of another fluid.
Now, gas turbines can be modified by adding turbine sections to extract more work from the hot gasses of combustion, and consequently reducing the thrust produced. The additional turbine sections are connected to an output shaft, which can turn a propeller or a generator. A gas turbine driving an aircraft propeller is called a turbo-prop. It works just as well with a ship propeller, with the addition of a reduction gear to the turbine so the propeller is driven at its most efficient speed, which is in the range of 100 RPM or so.
One of the limiting factors in the design of a gas turbine is the material used to construct the turbine blades. These blades must be very strong, so they do not break when being spun at high RPM, and they must remain strong while they are very hot. Due to various factors, it's not practical to use any cooling system for the blades.
