Thermodynamics-how to tell if a gas is an ideal gas?
  • Thread starter Thread starter pyroknife
    Gas Ideal gas
An ideal gas is defined by its behavior under specific conditions, primarily high temperature and low pressure. In the discussion, nitrogen at 300 kPa and 227°C is identified as an ideal gas due to its proximity to these conditions. The concept of ideal gases is theoretical, and real gases can exhibit ideal behavior when subjected to high temperatures and low pressures. There are tables available that list gases and their specific heat capacities (CP), which can aid in determining their ideal gas behavior.
  • Understanding of ideal gas laws and concepts
  • Familiarity with specific heat capacities (CP) of gases
  • Knowledge of thermodynamic principles
  • Basic grasp of pressure and temperature relationships in gases
  • Research the Ideal Gas Law and its applications
  • Explore tables of specific heat capacities (CP) for various gases
  • Study the conditions under which real gases approximate ideal gas behavior
  • Learn about thermodynamic processes and their impact on gas behavior
Students and professionals in physics and engineering, particularly those studying thermodynamics, gas behavior, and related fields.
pyroknife
I know a gas is ideal if it has a higher T or low P relative to its CP.
A probably stated that nitrogen is at 300kPa and 227 deg C. The solutions says its an ideal gas, but how does it know? Is it just same to assume that or is there an actual table that has gas's and their CPs?
Hey pyroknife
Ideal gas is a theoretical concept
And real gas tend show ideal gas behaviour at high temperature and low pressure ( both) .
Can you please elaborate your problem ?
  • · Replies 33 ·
  • · Replies 17 ·
