Thermodynamics -- Internal Energy
15 replies · 6K views
BurningUrge
I've read back and forth in my chapter and tried consulting with my formula sheet, but I cannot seem to find the correct formula. I bet I am looking at this question wrong, but I am fairly sure I need to use the -100 kJ for something to find the final volume and pressure , along with the given pv2=constant.
Basically, given the information below, how would you go about starting to solve this?
A mass of gas at an initial pressure of 28 bar, and with an internal energy og 1500 kJ, is contained in a well-insulated cylinder of volume 0.06m3. The gas is allowed to expand behind a piston until it's internal energy is 1400 kJ; the law of expansion is pv2=constant. Calculate:
1) the work done (Already calculated, -100kJ)
2) the final volume
3) the final pressure
Okay, so the work done is by the internal energy as it expands.
So Q + W = U1-U2. Since there is no heat transfer, only work done, it's basically only W = U1-U2.
W = 1500 kJ - 1400 kJ => W = 100 kJ. But since it's an expansion done BY the internal energy as it is allowed to expand, it's -100kJ.
The equation should be Q + W = U2-U1. That's why W is negative (using the sign convention that W represents work done on the system).
Now you need to develop another equation for expressing the work in terms of the pressure and volumes. What is the equation you learned for determining the work as an integral involving pressure and volume?
Chet
That would quite probably be this nifty little thing;
W = -∫pdV , from position 1 to 2. (Couldn't find the icon for definite integral)
Since pv2 = Constant, I rewrite the equation to -> -∫ c/V2 dV, => -c ∫ 1/V2 dV => -p1V12 ∫ 1/V dV.
When I can't write the correct definite integral it looks abit messy, but the finished integration should look like this;
-p1V12 (-1/V2-(-1/V1)
Finishing this off with :
-p1V12 (-1/V2-(-1/V1) = -100kJ
Am I currently on the right path?
-p1V12 (-1/V2-(-1/V1) = -100kJAm I currently on the right path?
Yes. I haven't checked your "arithmetic," but you're on the right path.
Chet
Okay, so I did that. And I came up with the right answers.
V2=0.148m3
And using that I could find the pressure as well with p1V12=p2V22
Ending at p2=4.6 bar.
Greatly appreciate your time and help!
I tried substituting into this formula you used but am not getting V2=0.148,am getting different answer.can you show your working here on how you got V2= 0.148 given the intial pressure and volume
Welcome to the PF. :smile:
This thread has been inactive for 5 years, but perhaps @Chestermiller can offer his thoughts...
Thank you,can you help me out with the appropriate substitution to arrive at the given answer V2=0.148m @berkeman
Substituting with the value of P1=28bar V1=0.06 and n=2 into the given equation:
2.8× 10^6×0.06^2(1/V2-1/0.06)=-100
Opening bracket:
10080(1/V2-1/0.06)=-100
10080/V2-1/0.06=-100
10080/V2-16.66=-100
Cross multiple and make V2 subject of formula:
10080-16.66=-100V2
10063.34/-100=-100V2/-100
V2=-100.6334
That is what am getting, please correct me if am wrong
Chestermiller said:
You are working in kJ and kbars. So that 2.8x10^6 should be 2.8x10^3.
Oh I got that,jus substituted 2.8×10^3 instead of 2.8×10^6 and my V2=1.5792 which is wrong,am still not getting the suppose as V2=0.148
Chestermiller said:
check your math
Oh thank you very much sir,I just figured out my mistake and corrected it
Am grateful for that correction
