Thermodynamics Pathria Eq.4.5.9
The discussion centers on the confusion regarding the derivation of equation 4.5.9 in thermodynamics, specifically the variables that define the internal energy U. The contributors clarify that temperature, chemical potential, volume, and particle number are involved, but only three of these four parameters are necessary to specify U. They explain the differentiation process needed to relate U to temperature, fugacity, and volume. The key steps involve setting certain differentials to zero and equating two expressions for dU, ultimately leading to the derivation of equation 4.5.9. The conversation emphasizes the importance of understanding the relationships between these thermodynamic variables.
IcedCoffee
I'm confused about the mathematics that led to the equation 4.5.9.
Specifically, I'm confused about what the variables that describe U are.
From the equation
I think temperature T(through beta), chemical potential (through alpha), V (through E_s) and N (through... restriction on the summation?) defines the (average) internal energy U,
but how should I do the differentiation? What I ended up was that the chemical potential dependence can be changed to the dependence on the fugacity z so that
but it doesn't seem to be exactly eq.4.5.9 to me.
Science news on Phys.org
I have the answer. It's going to take me a few minutes to write out the partial derivatives in Latex... ## \\ ## ## z=z(T, N,V) ##, so that ## U(T,z,V)=U(T,N,V) ## . ## \\ ## Three parameters are need to specify ## U ##, not 4 . Any 3 of the 4, (##z,T,N,V ##), can be chosen.## \\ ## Now using the first expression for ## U ##, ## \\ ## ## dU=(\frac{\partial{U}}{\partial{T}})_{z,V} \, dT+(\frac{\partial{U}}{\partial{z}})_{V,T} \, dz+(\frac{\partial{U}}{\partial{V}})_{z,T} \, dV ##. ## \\ ## Taking the second expression: ## \\ ## ## dU=(\frac{\partial{U}}{\partial{T}})_{N,V} \, dT+(\frac{\partial{U}}{\partial{N}})_{V,T} \, dN+(\frac{\partial{U}}{\partial{V}})_{N,T} \, dV ##. ## \\ ## Now, set ## dz=0 ## and ## dV=0 ##, and set the two ## dU's ## equal. Take a partial w.r.t. ## T ## at constant ## z,V ##, (we set ## dz ## and ## dV=0 ## ), =divide through by ## dT ## everywhere, and the result is the equation 4.5.9. ## \\ ## @Chestermiller This is a good thermodynamics problem that the OP has. Might you have anything to add?
@IcedCoffee You have a very interesting question, but so far you haven't returned to see the answer.
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
