Thermodynamics: Where exactly does microscopic turn to macroscopic?
The transition from microscopic to macroscopic in thermodynamics is not defined by a specific distance scale but rather by the number of particles involved. Statistical methods can effectively describe systems with as few as 100 particles, while larger systems may still exhibit noticeable effects even with around 10^12 particles. The subtlety of the effects being analyzed influences this transition point. Understanding this relationship is crucial for applying thermodynamic principles accurately. Overall, the shift from microscopic to macroscopic behavior is complex and varies with the system's characteristics.
mikeph
Looking for a rough distance scale over which statistical methods begin to work, and macroscopic thermodynamic variables begin to make sense. Thanks
Science news on Phys.org
It is rather not distance scale, but number of particles involved.
It depends on how subtle effects you want to describe.
Sometimes 100 particles may be successfully treated as a thermodynamical continuum, sometimes 1012 or so still produce visible effects (Brownian moves) beyond continuous thermodynamics.
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
