ThermodynamicsL Heat, Energy and Work Problem
Tethys
Hello! I've been a long-time follower of the Physics Forums and have found it to be a great resource for a variety of physics and engineering topics, although I have not actually felt compelled to create an account on the boards until today. I have encountered a difficult thermodynamics problem in a homework assignment that I would like some input on. I have changed some of the numbers from the original problem because I would like to actually solve the given problem myself, but the concepts are the same.
Relevant equations
Steady-flow energy equation: Q_cv + sum of m_i(h_i + V_i^2/2 + g Z_i) = W_cv + sum of m_e(h_e + V_e^2/2 + g Z_e).
Part One of the Problem
Schematic of a steam power cycle: a pump labeled 1 and W_p feeds a boiler labeled Q_in, then state 3 leads to a turbine that outputs W_t, exiting at state 4 with state 2 between pump and boiler.
Water passes through a pump in a steady-state process in which there is no height change, no heat transfer, and a constant temperature across the device. The water initially has a pressure of 15 kPa and a temperature of 53.97 C, and it leaves the pump with an exit pressure of 5MPa. How much work is required to pressurize the water if the mass flow rate through the pump is 25 kg/s? Define the phase of the water at State 1 and State 2, and draw the process on a T-v diagram (v is specific volume).
Part Two of the Problem
The water is converted into steam in a constant-pressure process after exiting the high-pressure pump. How much heat is transferred to the water if the steam temperature is 500 C coming out of the bioler? What is the phase of the water at State 3? Draw the process on a T-v diagram.
Part Three of the Problem
Compute the turbine work output and draw the T-v diagram if the exit velocity from the turbine is 150 m/s and the steam expands through the turbine until it is saturated water at 15 kPa and 90% quality.
Much thanks in advance for the help and input,
-Tethys
Bump! I could really use some help on this. Any input is appreciated.
Part 1
From the given information, it appears that this is an adiabatic process as well as an isentropic process.
H = U + pV ---> h = u + pv (expressed per unit mass)
U = KE + PE = .5mV^2 + mgh
Qcv = 0
mi = me
KE is constant so (V^2)/2 can be canceled from both sides (?)
The potential energy term (gZ) can also be cancelled?
How does the summation in the above equation affect the ability to cancel equivalent terms?
From the given information:
P(1) = 15 kPa P(2) = 5 MPa
T(1) = 53.97 C = 327 K
Mass Flow (.m.) = 25 kg/s
Initial State = Liquid = Final State
From thermodynamic steam tables:
v(1) = 0.001014 m^3/kg
v(2) = 0.001014 m^3/kg
u(0) = 225.9 kJ/kg
u(2) = 225.1 kJ/kg
Why would an increase in pressure result in a decrease in internal energy?
W = -int(pdV) (V(1) - V(2))
Volumes aren't given, so can this be written per unit mass? Would this even help?
This problem has me stumped at the moment. I have an assessment coming up that covers this type of material, and I am having trouble getting a handle on how to solve problems of this type. If anyone can elucidate the methodology for solving the given problem I will be very grateful.
-Tethys
Part 1:
The given requation, when all equivalent terms are cancelled, and irrelivent terms removed simplifies to:
-w = h2 - h1
where all terms are per unit mass.
From steam tables,
h2 = 230.1 kJ/kg
h1 = 225.9 kJ/kg
So:
-w = 230.1 - 225.9 = 4.2 kJ/kg
And the work flow rate can be found using the mass flow rate:
.W. = w(.m.) = (-4.2 kJ/kg)(25 kg/s) = -105 kJ/s
From the wording of this problem, I initially assumed that it was asking for the total work term, but the fact that there are no mass terms given in the problem makes me think that the work flow is actually what it is asking for. Is this correct??
If somebody could verify the method and/or answer that would be great!
Part 2
Further simplification of the given equation gives the following relation for Part 2:
q + h2 = w + h3
h2 = 230.99 kJ/kg
h3 = 3434.7 kJ/kg
There is no work in this step, so:
q = h3 - h2 = 3434.7 - 230.99 = 3203.7 kJ/kg
The heat flow rate can be found using the mass flow rate:
q(.m.) = (3203.7 kJ/kg)(25 kg/s) = 80,092.75 kJ/s = .Q.
Is my assumption that this problem is asking for the Heat Flow Rate correct?
Part 3
This part is calculated in a similar fashion as the previous two, with the given relevant equation simplifying to:
-w = h4 - h3
h4 is calculated from the given quality (90%) and given pressure (15 kPa) rather than T and P from the steam tables.
-w = 2362 - 3434.7 = -1072.7 kJ/kg
w = 1072.7 kJ/kg
Verification of methodology and/or prospective answer would be appreciated!
Bump! It would be great if I could get some verification on how I worked this problem before I use the same methods to solve the original version (which has different temperature, pressure, and mass flow numbers).
I don't mean to complain, but I've had this problem up for four days now, and I haven't gotten any input so far. I've been a fan of the physics forums for a long time, and I am honestly a little surprised that nobody has offered any assistance on this.
