Thevenin's equivalent circuit problem
5 replies · 13K views · last reply
backstance
use thevenin's theorem to find the current in the 3 ohm, parallel branch, resistor
http://img217.imageshack.us/img217/909/img0267cc7.jpg
Thevenin equivalent circuit, voltage divider rule
I don't think its possible, since thevenin's theorem ends up with a voltage source and a resistor in series, you can only find currents and voltages in components that are in series. In this circuit there is nowhere to make the cut and split the circuit across terminals A and B. Normally you'd need Norton's equivalent circuit to find the current in the 3ohm resistor. Am I right, or is there actually a solution using thevenin's?
Could anyone solve this problem?
  • AC circuit schematic with a sinusoidal voltage source Sin(ωt+90) on the left, a 2 Ω resistor, a current source I = 2 Cos(ωt), and impedances J3 Ω, -J2 Ω, J2 Ω and J4 Ω, with current i(t) marked and the caption 'Find i(t), f = 60 Hz. and mutual inductance is j2'.
any ideas? any help would be appreciated, thanks!
http://www.allaboutcircuits.com/vol_1/chpt_10/8.html
try and study it from the url. The circuit is quite the same as yours.
