Thoroughly confused on self-inductance
  • Thread starter Thread starter darksyesider
    Confused
Self-inductance refers to the ability of a conductor to generate a voltage in response to changes in current, resisting changes in current flow. The discussion clarifies that self-inductance operates on the same principles as mutual induction, where a changing magnetic field induces an electromotive force (EMF) in the conductor. The EMF generated opposes the change in current, acting against increases and supporting decreases in current. When calculating magnetic flux, any surface can be used, but the choice should simplify the problem, considering the symmetry of the situation. Understanding these concepts can help clarify the confusion surrounding self-inductance.
darksyesider
I am havingA LOT of trouble with self-inductance and have spent 10+ hours watching videos on youtube, and I'm still getting nowhere.
From what I understand:
self inductance = the ability of a thing (not sure what) to resist the change in voltage (and thereby causing current to change more steadily. (is this right?)
In my textbook derivation of the self-inductance of a coaxial cable, they took a cross section like here:
http://www.phys.nthu.edu.tw/~thschang/notes/GP32.pdf (page 8)
I don't really get this at all intuitively, because can't you choose any cross section?? How do you know where to find the surface which you want to get the flux of?
I guess the problem is that, I feel as if you need to multiply the result by 2pi*r to get the whole entire cylinder, however this is not true.
Please help (and if you happen to know a good analogy for self-inductance, please share because i am very confused )
Self inductance is the creation of a voltage in a conductor when the current through that conductor changes. It is important to understand that the basic principles of self induction are no different than mutual induction. A change in current through a conductor causes the magnetic field generated by that conductor to change. This change in the magnetic field generates an EMF in the conductor itself as well as any nearby conductors.
The EMF generated in self induction always tries to resist the change in the current. That is, if the current is increasing, the EMF will be against the direction of current. It will oppose it. If instead the current is decreasing, the EMF generated will act to keep the current flowing.
Thanks. Also, in the equation:## emf = \dfrac{d\phi_B}{dt}##
how do you know which surface to take the flux of?
You can take any surface and calculate flux through it. The result does not depend on the shape of the surface, only on the closed curve that is its boundary.
As Jano L. said the law applies to any surface. When solving problems you should for a surface that simplifies the problem as much as possible often taking the symmetry of the physical situation into account.
  • · Replies 16 ·
  • · Replies 23 ·
  • · Replies 16 ·
