Thought experiment - water at the bottom of the sea
The discussion centers on the behavior of water in a closed pipe lowered to the bottom of the ocean, where temperatures range from 0-4 degrees Celsius. When the pipe is opened, the dense, pressurized water rises due to the weight of the water column above it. As the water ascends, the pressure equalizes, halting further flow once it reaches sea level. The conversation also touches on oil drilling dynamics, where pressure from surrounding rock allows oil to spout, contrasting with the water scenario due to density differences.
  • Understanding of hydrostatic pressure principles
  • Knowledge of fluid dynamics, particularly Bernoulli's equation
  • Familiarity with the behavior of gases under pressure
  • Basic concepts of energy conservation in physical systems
  • Research "Bernoulli's equation and its applications in fluid dynamics"
  • Explore "Hydrostatic pressure calculations in fluid systems"
  • Investigate "The effects of temperature on fluid density and pressure"
  • Learn about "Energy conservation principles in mechanical systems"
Physics students, engineers, and anyone interested in fluid dynamics and pressure systems, particularly in relation to oceanography and drilling technologies.
MulderFBI
So as we know at the bottom of the ocean we have water cooled to 0-4 degrees celsius which is very dense and also compressed due to the pressure.
Imagine we lower a few kilometres long pipe to the bottom of the ocean (it's made of material that is strong enough to sustain pressure). It's closed and filled with air. What happens if we open it after reaching bottom of the ocean? Would that pressurized, dense water go upwards pipe and shoot out at surface?
The water would rise in the pipe until it reaches sea level and then stop.
So all the pressure is lost during the way upwards?
What causes the pressure at the bottom? The weight of the water above pressing down. What happen as water begins to rise in in the pipe? As the column of water gets taller, it gets heavier. When the water column in the pipe reaches sea level, the weight of the water in the pipe causes the pressure at the bottom inside the pipe to be the same as the pressure outside the pipe. No pressure difference means no more water enters the pipe.
This was my understanding. But then I was also thinking about drilling for oil and hitting a reserve and it fountains out the top of the rig.
I have to assume that it's the overlaying rock that is putting the oil pocket under pressure and that pressure is also going to decrease as it approaches the surface, yet it still spouts !
Does it do so because the rock is denser than the oil where-as in the OP it is water in the pipe and a water column outside it giving the pressure and no spouting out the top of the pipe because the density is the same ??
Am not sure if it's the density difference or something else
Ohhh ---- the oil at depth is going to be quite hot ( temp increases 23C / km = from my old geology days) ... that will increase the pressure :smile:
Dave
The work that you would have to put into forcing that empty pipe to a depth of 2km would be the same as the work you would get out. As compressed water is admitted into the empty pipe, it will expand to its normal density (a bit of an incidental, actually) pressure at the bottom will force more and more water into the pipe and the water will accelerate. By the time it reaches the surface, it will still have a vertical velocity so you can expect it, indeed, to shoot out at the surface if the pipe is wide enough to cause low drag. If the pipe end is significantly above the surface then the movement will carry the level high than the sea surface but then the level will fall back until there is equilibrium. The level will oscillate and will reach equilibrium as the kinetic energy is dissipated. This is the same with water in a U tube.
Not the way to look at it. Pressure at the bottom of the column in the pipe will approach that of the surrounding water. Pressure at the top of the column will always be just Atmospheric (plus up to 2km of air). Density of water in the pipe will accord with the local hydrostatic pressure at any point. You can assume that there is no appreciable lag in change of density with pressure.
Can we increase pressure in the pipe somehow? For example with adding atmospheric air at some point? Water from the bottom of the ocean is oxygen deficient if we combine it with air that might increase pressure or am I mistaken?
There is no reason this should remain a thought experiment. Get a tub of water and a straw. Seal the end of the straw. Stick it under water and cut off the seal. What happens?
Edit: or just plug it with your finger and unplug it once it is at depth
You could pump air down to the bottom of the pipe or push a sealed container down and open it down there BUT the energy that would require would be slightly more than the energy you could harvest from the water "shooting out at the top".
No such thing as a free lunch as far as energy is concerned. Google "conservation of energy".
PS: It would be more energy efficient and cheaper just to install a pump at or hidden just below the surface and make your fountain that way.
I am aware of the law of energy conservation but I imagine that if oxygen deficient water starts absorbing atmospheric air then that air would start to be sucked into the pipes thus maintaining pressurized flow? I am talking here about using some kind of a membrane that allows air particles in but it doesn't allow water out into air pipe. It's hardly to run out of the air and ocean water so could that flow be utilized to generate energy?
I am by no means expert and my whole reasoning is propably wrong but I just wanted to verify some claims and that's why I ask experts ;)
Sorry, but that just isn't a "thing".
"... pumping of gas-rich bottom waters to the surface of the lakes through pipes. ... In the initial gas burst at Lake Nyos, a gas-water fountain was produced that was at least 80 m high and washed over a large rock promentory in the lake with enough force to erode away the soil and vegetation down to bare rock. In addition, a surface wave was produced that was at least 25 m high. Therefore, tremendous energy was released by the dissolved gas as it expanded during the gas burst in 1986.
The energy released during degassing is sufficient to drive the pumping operation without any external power source."
https://globalchange.umich.edu/globalchange1/current/lectures/kling/killer_lakes/killer_lakes.html
Relevant?
Try putting a straw in a bucket of water. Cover the ends of the straw and put it in the bucket, and release the ends. What happens?
Relevant?
But that energy came from the release of already compressed gases. To get the same effect in an experiment you would, as has been said several times earlier, need to put in the energy in the form of mechanical work in order to get it our again (less the inevitable losses.
We are not in a dreaded 'harvesting' situation here.
From my experiment, proposed by Dale and Khashishi, yes.
I read somewhere that straws are bad for the environment, so I used an ≈40 year old fish tank under-gravel filter tube:
total length: 220 mm
inner diameter: 20 mm
immersion depth: 69 mm (3 run average when eyeballing for 70 mm)​
So my tube extends both below and above the surface of my artificial ocean(a pint glass).
Somewhat different, but my experiment, when the tube top was at the waterline, clearly showed that water squirted out the top.
Anyways, here are the results of my experiment:
For a frictionless tube and an incompressible fluid, free of viscosity one would expect simple harmonic motion with a peak as far above the surface as the starting point was below.
Were I not on a "retiree" on an "ehr mehr gerd, ehrm pehr!" budget, I would invest in such things.
"a frictionless fountain"!
I've always wanted one of those.
No chance, now we have global warming, I'm afraid.
https://www.sciencelearn.org.nz/resources/688-ocean-dissolved-gases
"...Deep water, which has a high pressure, holds more gas than shallow water..."
Net gain of energy from mechanical(ok, hydraulic) oscillator - physics says "NO".
But scaling 2km pipe and bathypelagic zone to 2m and a barrel introduces some simplifications into experiment - namely pressure/density changes and outgassing.
That's what I was hinting at (:
In a once-off occurrence then the expansion of bubbles - even when not in solution - produces this sort of effect because of the Potential Energy stored in the compressed gas. I can't make up my mind if the outgassing would provide more or less energy.
Some years ago there was a lake by a volcano. There were fissures deep underwater that emitted CO2 gas, which dissolved in the cold water.
Something disturbed the lower water (landslide, I think) causing some of the CO2 saturated water to move up. Dropping pressure allowed the CO2 to come out of soluiton. This lowered the density. The water rose faster, and pulled more saturated water from below. The reaction cascaded, and ended up with several lake volumes of CO2. Since the CO2 had done work rising, it was cold. The cold bubble of CO2 flowed down hill, and killed a village.
To prevent a recurrence, they have done something very simple: They've dropped a long pipe to the level the CO2 is injected into the lake. The pipe is basically hung from a raft. A small solar powered pump pulls water from the top of the pipe. Most of the time, it just sits there pumping a a litre a minute or so. If the CO2 builds up enough, it will start coming out of solution, and the raft becomes a fountain. The pipe keeps the lake from carrying on with a massive spill.
In this case the work to power the fountain is done by the Earth's volcanic activity injecting gas into the water. Sorry, no free lunch.
Nice story. A small leak prevents build up. Someone had a smart idea.
I am talking routine potential energy conversion to kinetic, within limits of "stick long pipe deep into water".
Without
part, it's ... how to say politely ... too much of a thought experiment.
https://link.springer.com/article/10.1007/BF02069879 - table, solubility of nitrogen in water under pressure.
0.1MPa/20OC - 0.0149 cm3/g, 500MPa/20OC - 4.978 cm3/g
You're hinting that I'm a "Omahgad, is it really free energy?!1" guy? No. But harvesting - yes.
In this case energy would come from ocean mixing currents(ultimately from Sun).
New thought experiment:
I pump water from 1km depth to surface using 10m diameter pipe.
At some point inside pipe, pressure change due to pumping and water column reduction creates dissolved gasses(mostly N2 i assume) oversaturation and outgassing in bubble form.
Resulting density change does work by moving unsaturated water upwards and sustains the process once the flow is laminar.
Energy lost due to water friction not a total waste - heat reduces water density/is useful.
Please criticize this one, i don't see any obvious holes(unless I'm wrong my assumption that dissolved gas in seawater is saturated).
You're wrong.
Please criticize this one, i don't see any obvious holes(unless I'm wrong my assumption that dissolved gas in seawater is saturated). [emphasis added]
Well, the bolded part is basically gibberish. Yes, the density changes as the water rises up the pipe (for several reasons; release of dissolved gases being the least of them if it even happens) but that doesn't make it self-sustaining nor does it have anything at all to do with laminar flow.
You could, however, use the expansion of the water from it warming up and de-pressurizing as it rises to drive a turbine, generating an absolutely miniscule amount of power that comes nowhere close to countering the loss from pumping the water out of the ocean.
Look, there are a host of ways that something dug or pumped out of the ground will absorb or release energy spontaneously when reaching the surface. Almost anything you pump or dig out of the ground will. But none of them come anywhere close to the energy value of the resource itself -- with the exception of geothermal energy in which the resource is heat which will be spontaneously absorbed or rejected it if not recovered.
Why only a tiny amount? Wouldn't the Potential Energy be reasonably significant? In general, compressed gases are a good way of storing mechanical energy (the energy put into compressing air into a scuba tank is enough to cause an explosion when a tank bursts.. The energy could be greater than the GPE involved in raising the gas (or even gas+water) by 2km which would be supplied by hydrostatic pressure from the sea. Nitrogen takes time to dissolve and evolve so the bubbles could form after the water was near or at the surface. (Diving tables for relatively shallow air breathing dives involve many minutes of decompression time.)
This thread is severely lacking in numbers, so here's a back-of-the-envelope calc (please feel free to check my math):
Here's a study of the solubility of CO2 in water, with data up to 1,000 ATM:
https://www.researchgate.net/publication/222567153_Solubility_of_CO2_in_water_from_-15_to_100C_and_from_01_to_100_MPa_Evaluation_of_literature_data_and_thermodynamic_modelling
It seems to drop off below 10C, but we can ignore that and use the 10C value (assuming it is saturated, which is a big assumption).
At 10C and 1000 ATM (equivalent depth 10,000m), the solubility is about 4% by moles. One cubic meter of water contains 55,555 moles of water and therefore 2222 moles or 286 cubic meters of CO2 at room temp and atmospheric pressure. Since solubility varies with pressure you only average half the pressure delta in the expansion, so the energy in the expansion is 14.3 megajoules. That's more than I would have expected, but by comparison:
-The thermal energy capacity of the water is 67 megajoules (with a 16C temperature rise).
-A cell phone battery is on the order of 32 megajoules.
-A cubic meter of diesel has an energy density of 35,800 megajoules.
So, miniscule.
Really? I'm having trouble thinking of a practical example where compressed air is used for energy storage. It is proposed for things like cars, but has yet to be practically implemented as far as I know. The best I can do is CO2 cartriges for specialty applications like paintball guns.
The fact that a scuba tank can explode doesn't really mean anything since it isn't being stored for its energy. Knocking over a building releases a lot of energy too...
I didn't include it as an example because as you say you can get it back if you have a piping loop, but no, it's nowhere close. For my example at 10 km depth, the GPE of 1 cubic meter of water is 98 MJ.
Air tools running off a compressed air tank are a good practical example. Air brakes with reservoirs for failsafe operation are another example.
  • · Replies 28 ·
