Three equations of motion homework
20 replies · 2K views
Viraam
## 2as = v^2-u^2 ##
## v = 0 ... \text{at maximum height}##
## \therefore s = \frac{-(u)^2}{2a} \\ a = -g \\ \therefore s = \frac{-(u)^2}{-2g} = \frac{(u)^2}{2g} ##
Please explain using only the Three equations of motion and not anything related to Energy or other formulae.
Is my answer correct:-
You are using the kinematic equations for uniformly accelerated motion. Do you think they would apply?
Yeah. Because they are uniformly accelerated to ## g ##
The acceleration is ## g ## when the balls are close to the Earth's surface. But those speeds are pretty high.
Ohh then please tell me how to find the Heights.
Doc Al said:
Use conservation of energy.
We haven't learned that. Can you please tell me the formula.
Some other sites states the following:-
##KE + PE \text{ at the surface} = PE \text{ at the maximum height}##
Can you please explain in simpler words because I am very new to this.
That's exactly the equation you need. Of course you need to learn how to express the gravitational PE.
If you haven't studied this yet, where did you get the problem?
We haven't learned it completely yet. But this question was in our chapter called Gravitation.
Good. So it should cover how you calculate the gravitational PE at some distance from a planet.
No we learned only these equations:-
##F = \frac{GMm}{R^2}\\ g = \frac{GM}{R^2}##
Do you mean this:-
## PE = mgh##
## PE = \frac{GMmh}{R^2}##
Viraam said:
So the answer is 4:1
How did you determine that?
Using
## KE + PE \text{ at surface} = PE \text{ at maximum height} ##
## \frac{1}{2} m *(2\sqrt{\frac{gR}{3}})^2 - \frac{GMm}{R}= \frac{-GMm}{R+h}\\
h = 2 R\\ \text{For the other ball:-} \\ h' = \frac{R}{2}\\ \frac{h}{h'} = \fbox{4:1}\\ ##
Viraam said:
Using
Looks right to me. Well done.
Viraam said:
Using
Good work! (Just wanted to check. :smile:)
Have a doubt. How exactly do we know when to use Gravitational Potential Energy. Please explain in the simplest words. Thanking you in advance.
That's difficult to answer. Just stating the obvious: When gravity is involved and a massive object changes position, you may be able to make use of gravitational PE. But it depends on the problem and what you need to find.
Ohh ok Thank you so much
