Three phase phasor proof or simplification
The discussion revolves around the concepts of phasors and space vectors in the context of electrical engineering, specifically focusing on the representation of sinusoidal functions and their transformations. Participants explore the mathematical relationships and proofs related to these concepts, including attempts to simplify or prove specific equations involving three-phase currents.
  • One participant expresses confusion about the representation of a space vector current and seeks clarification on its derivation.
  • Another participant notes the distinction between phasors and space vectors, explaining that phasors represent time-invariant sinusoidal functions while space vectors relate to complex-valued functions with spatial interpretations.
  • Some participants suggest converting terms to their complex representation and performing algebraic manipulations to clarify the relationships.
  • There is a discussion about the nature of phasors, with some participants asserting that phasors are complex constants without time dependency, while others question how this relates to the presence of time variables in the original expressions.
  • A later reply emphasizes that space vectors do not involve phasors and that the two concepts belong to different analytical frameworks.
  • Participants share mathematical identities and transformations that they believe may help in simplifying the expressions, but there is no consensus on the correctness of these approaches.
Participants generally agree on the definitions of phasors and space vectors, but there is disagreement regarding their relationship and the correct approach to simplifying the given equations. The discussion remains unresolved as participants explore different perspectives and mathematical techniques.
Some participants mention specific mathematical identities and transformations, but the discussion does not resolve the assumptions or limitations inherent in these approaches. There are also unresolved questions about the implications of time dependency in the context of phasors.
tim9000
So I'm really rusty on phasors, I was reading that a space vector current was
i(t) = I(cos(wt)<0 + cos(wt - 120)<120 + cos(wt - 240)<240 ) = 3/2 * I < wt
and I couldn't figure out how that could be so (still can't, please help)
So I tried to go back to basics and I went back and read:
A = CosΘ.Cos(wt) + Cos(Θ - 120).Cos(wt - 120) + Cos(Θ + 120).Cos(wt + 120)
= 3/2 * Cos(Θ - wt)
so I went back to Trig identities...and pages of scribbling later still couldn't figure it out.
Does anyone have a proof for either of these?
Thanks!
A note: phasors and space vectors are two very different concepts.
- A phasor is a representation of a sinusoidal function with parameters that are time-invariant.
- A space vector is a transformation that maps a set of real-valued functions to a complex-valued function, which usually has some type of spatial interpretation (used a lot in electric machine theory).
Have you tried converting all the terms to their complex representation? Then do a bit of algebra.
- A space vector is a transformation that maps a set of real-valued functions to a complex-valued function, which usually has some type of spatial interpretation (used a lot in electric machine theory).Have you tried converting all the terms to their complex representation? Then do a bit of algebra.
Yeah as far as I remember a space vector is the addition of phasors through feeding a sineusoidally current to a sineusoidally distributed winding in space.
Yeah I tried that thanks.
As you can see in what you quoted the angle term becomes the frequency * time. It should be simple, I'm just not doing something right.
What about:
= 3/2 * Cos(Θ - wt)
no idea how it reduces to that?
tim9000 said:
Yeah as far as I remember a space vector is the addition of phasors ...
No, phasors aren't involved at all when you're working with space vectors, which is a good thing, since you'd otherwise be limited to steady-state analysis.
If you have a function ##i(t) = A\sin(\omega t + \theta)##, where ##A, \omega, \theta## are constants, then its phasor representation is ##I = Ae^{j\theta}##.
If this:
$$ \mathbf{i_s} = i_a(t) + i_b(t) \mathbf{a} + i_c(t) \mathbf{a}^2, \mathbf{a} = e^{2\pi/3}$$
is the space-vector transformation, then, for instance, the term ##i_b(t) \mathbf{a}## is not a phasor, even though it is complex. ##i_b## is just an arbitrary real-valued function of ##t##, and ##\mathbf{a}## isn't a phasor representation of a sinusoidal function.
tim9000 said:
... through feeding a sineusoidally current to a sineusoidally distributed winding in space.
##i_a, i_b, i_c## aren't restricted to sinusoidal functions, and the space-vector transformation is just as useful for windings that aren't sinusoidally distributed.
I can help you with the algebra if you show your work.
Try doing the complex algebra first.
Could please you elaborate on that?
Anyway isn't what I've posted just phasors?
That was the purpose of the rest of my post. Can you be a bit more specific? :smile:
No, a phasor is a complex constant, i.e. they have no time dependency.
tim9000 said:
... I(cos(wt)<0 + cos(wt - 120)<120 + cos(wt - 240)<240 ) ...
None of these terms are phasors.
Edit:
Just to reiterate: a phasor is a complex constant, but not all complex constants are phasors. As I wrote, a phasor encodes the time-invariant amplitude and phase of a sinusoidal function.
You can have voltage and current phasors, but their complex ratio, the impedance, isn't a phasor, since it doesn't encode the parameters of a sinusoidal function.
Oups, that should be ##\mathbf{a} = e^{j2\pi/3}##.
ok thanks, found the paper:
=[ei(wt)+e-i(wt)]/2 + [ei(wt +120)+ei(wt + 120)]/2 * (-1/2 + i√3/2) + [ei(wt -120)+ei(wt - 120)]/2 * (-1/2 + i√3/2) = ...
And
= 3/2 * Cos(Θ - wt)
using: sin(wt).sin(Θ) = [Cos(Θ - wt) - Cos(Θ + wt)] / 2
and Cos(a).Cos(b) = Cos(a - b) + sin(a).Sin(b)
cos(Θ - wt) + sin(wt).sin(Θ) + cos(Θ - 120 -(wt - 120)) + sin(Θ - 120).sin(wt - 120) + cos(Θ + 120 - (wt + 120) )+ sin(Θ + 120).sin(wt + 120)
cos(Θ - wt) + [Cos(Θ - wt) - Cos(Θ + wt)] / 2 + cos(Θ - wt) + [cos(Θ - wt) - cos(Θ + wt + 240)] / 2 + cos(Θ - wt) + [cos(Θ - wt) - cos(Θ + wt + 240)/2 = ...
cheers!
Edit:
hmm,
so are you saying the thing that makes it a phasor is that there is not 't', the 'wt' is implicit, you have to keep it in the back of your mind? Like a phasor has an invisible frequency, but the phasor itself just a complex value?
Not exactly. What makes a complex constant a phasor is the mapping it represents. It's just a compact way of representing a sinusoidal function with time-invariant parameters, which, in the framework of steady-state AC analysis, is very convenient mathematically to work with. But this is really getting away from the point I was trying to make:
Space vectors have nothing to do with phasors. There are no complex constants, like ##Ae^{j\theta}##, which maps to a sinusoidal function, present in this expression:
i_a(t) + i_b(t) \mathbf{a} + i_c(t) \mathbf{a}^2, \mathbf{a} = e^{j2\pi/3}
You're just working with complex numbers here. Phasors belong in a completely different framework.
There are similarities between space vectors and symmetrical components, in which you actually do work with phasors, but the theory of symmetrical components only deal with steady-state analysis, which is the crucial difference.
I sort of hear what you're saying, I'll endevour to think about it more, I think some specific maths would help. What did you think of the track I went down with my working for the initial two expression derivations?
Cheers
Focusing on the first bit, I'd start with polar form. It'll make the algebra lot easier:
\cos(\omega t) + \cos(\omega t + 2\pi/3)e^{j2\pi/3} + \cos(\omega t - 2\pi/3)e^{-j2\pi/3}
I can see in your script the last negative is there, but for some reason it didn't display on my browser.
Right, well, I suppose I could factor out the ej2pi/3
Cos(wt) + ej2pi/3[cos(wt + 2pi/3) + cos(wt - 2pi/3).e^-1]
...actually that didn't help
So I suppose those trig relations were of no relevance?
Sorry, this is embarrassing
You were on the right track before by converting the cosines to their complex form. I just wanted you to start out with:
instead.
No it's not :smile:.
I appreciate your tact.
So If I leave the Cosines in their current form, how can I simplify them?
Thank you
P.S also what about:
= 3/2 * Cos(Θ - wt)
Convert the complex exponentials to their rectangular form (like you did), i.e. ##e^{j2\pi/3} = -\frac{1}{2} + j\frac{\sqrt3}{2}, e^{j4\pi/3} = -\frac{1}{2} - j\frac{\sqrt3}{2}##, expand terms, and see what you get.
= 3/2 * Cos(Θ - wt)
There's probably a more elegant way to show it, but I'd just use the angle sum identities, so you have, for instance:
\cos\left(\theta - \frac{2\pi}{3}\right) = \cos(\theta)\cos\left(\frac{2\pi}{3}\right) + \sin(\theta)\sin\left(\frac{2\pi}{3}\right) = -\frac{1}{2}\cos(\theta) + \frac{\sqrt{3}}{2}\sin(\theta)
and expand terms.
milesyoung said:
Convert the complex exponentials to their rectangular form (like you did), i.e. ej2π/3=−12+j3√2,ej4π/3=−12−j3√2e^{j2\pi/3} = -\frac{1}{2} + j\frac{\sqrt3}{2}, e^{j4\pi/3} = -\frac{1}{2} - j\frac{\sqrt3}{2}, expand terms, and see what you get.
Very well, here goes:
i(t) = I(cos(wt)<0 + cos(wt - 120)<120 + cos(wt - 240)<240 ) = I[ cos(wt) + cos(wt + 120)*(-0.5 + j√3/2) + cos(wt + 240)*(-0.5 - j√3/2)]
= ... what am I not seeing?
= 3/2 * I < wt
= 3/2 * I < wt
Did you have a look at the angle sum identities?
Ah, I see:
= I[ cos(wt) + (j√3/2-0.5)*(-0.5*cos(wt) + √3/2*sin(wt) - 0.5*cos(wt) - √3/2*sin(wt))]
=I[ 1.5*cos(wt) - j√3/2*cos(wt)] ...hmm I don't have a calculator on me atm, but if we just took the real part that'd be right?
= 3/2 * I < wt
tim9000 said:
Ah, I see:
= 3/2 * I < wt
do you just take the real part?
No, what's the reasoning?
This:
tim9000 said:
... cos(wt - 120)<120 + cos(wt - 240)<240 ...
should reduce to this:
\frac{1}{2}\cos(\omega t) + j\frac{3}{2}\sin(\omega t)
using the angle sum identities. Check your algebra carefully.
Fair call.
12cos(ωt)+j32sin(ωt)​
Right you are:
= I[cos(wt) + (-0.5 + j√3/2)*(-0.5cos(wt) - √3/2*sin(wt)) + (-0.5 - j√3/2)*(- 0.5*cos(wt) + √3/2*sin(wt))]
= I[cos(wt) + -0.5*(-0.5cos(wt) - √3/2*sin(wt) - 0.5*cos(wt) + √3/2*sin(wt)) - j3/4*sin(wt) - j3/4*sin(wt)]
= I[cos(wt) + 0.5*-cos(wt) - j3/2*sin(wt)]
So I [ 0.5*cos(wt) - j3/2*sin(wt)] is 3/2<wt?
Thanks very much
This:
Hey,
As in post #22, So getting from [ 0.5*cos(wt) - j3/2*sin(wt)]
to 3/2<wt
Is that a conceptual leap rather than a mathematical one?
Thanks
to 3/2<wt
It's true that:
\cos\left(\omega t - \frac{2\pi}{3}\right)\mathbf{a} + \cos\left(\omega t - \frac{4\pi}{3}\right)\mathbf{a}^2 = \frac{1}{2}\cos(\omega t) + j\frac{3}{2}\sin(\omega t)
but you still need to add the ##\cos(\omega t)## term. Then apply Euler's formula.
milesyoung said:
It's true that:
I'm really sorry, but what do you mean? :oops:
There's nothing to be sorry about.
This is what you posted originally:
Notice that besides:
You also have:
You also have:
Ah, I see what you're saying, but didn't I have:
cos(wt) -0.5*cos(wt) in the final expession, so wasn't that cos(wt) accounted for?
Cheers
\begin{align*}
\cos\!\left(\omega t - \frac{2\pi}{3}\right)\mathbf{a} &= \left(-\frac{1}{2}\cos(\omega t) + \frac{\sqrt{3}}{2}\sin(\omega t)\right)\left(-\frac{1}{2} + j\frac{\sqrt{3}}{2}\right)\\
&= \frac{1}{4}\cos(\omega t) - \frac{\sqrt{3}}{4}\sin(\omega t) - j\frac{\sqrt{3}}{4}\cos(\omega t) + j\frac{3}{4}\sin(\omega t)\\\\
\cos\!\left(\omega t - \frac{4\pi}{3}\right)\mathbf{a}^2 &= \left(-\frac{1}{2}\cos(\omega t) - \frac{\sqrt{3}}{2}\sin(\omega t)\right)\left(-\frac{1}{2} - j\frac{\sqrt{3}}{2}\right)\\
&= \frac{1}{4}\cos(\omega t) + \frac{\sqrt{3}}{4}\sin(\omega t) + j\frac{\sqrt{3}}{4}\cos(\omega t) + j\frac{3}{4}\sin(\omega t)
\end{align*}
And then you have:
\begin{align*}
&\frac{1}{4}\cos(\omega t) - \frac{\sqrt{3}}{4}\sin(\omega t) - j\frac{\sqrt{3}}{4}\cos(\omega t) + j\frac{3}{4}\sin(\omega t)\\
+ &\frac{1}{4}\cos(\omega t) + \frac{\sqrt{3}}{4}\sin(\omega t) + j\frac{\sqrt{3}}{4}\cos(\omega t) + j\frac{3}{4}\sin(\omega t)\\
= &\frac{1}{2}\cos(\omega t) + j\frac{3}{2}\sin(\omega t)
\end{align*}
so check your algebra again carefully.
So was what you were saying before, if the 'x' in:
has a frequency, I can see that the magnitude would rotate around the zero between the real and imaginary planes, but are you saying that's true for...
Hmm I'd better start again, that ...<wt on the magnetising current, what is that actually indicating?
I'm going to take your advice, so I better go over it in the morning...or afternoon, it's 4:20am here.
Cheers!
Say you have some complex number ##z = re^{j\phi}##. The ##re^{j\phi}## bit is its polar form, which you can think of as a vector in the complex plane with magnitude ##r## and angle (phase) ##\phi##.
The complex number ##\frac{3}{2}e^{j\omega t}## then represents a vector of constant magnitude ##\frac{3}{2}##, which is rotating counterclockwise in the complex plane with angular frequency ##\omega##. See here for an illustration.
That's exactly the result you would expect in the framework of space vectors as they relate to electrical machines.
The vector shows you what happens if you apply a balanced set of three-phase currents to the stator of a symmetrical machine: it produces a stator current space vector, which rotates CCW in the plane normal to the rotor axis of the machine. There's no actual current with any spatial direction, that's nonsense, but the stator current space vector is aligned with the magnetic axis of the resulting stator field, which makes it a very useful abstraction (and one of the many great properties of space vectors).
  • · Replies 22 ·
