Three Point Charges, find the electric force exerted
3 replies · 6K views · last reply
m00nbeam360
Three charges, each of magnitude 2 nC, are at separate corners of a square of edge length 1 cm. The two charges at opposite corners are positive, and the other charge is negative. Find the force exerted by these charges on a fourth charge q = +3 nC at the remaining (upper right) corner. (Assume the +x axis is directed to the right and the +y axis is directed upward.)
k = (8.988*10^9 N*m^2/C^2)
Drew a diagram of the problem such that F4 = F1,4 + F2,4 + F 3,4.
F1,4 = (k*q1*q4)/(r(1,4)^2)j
F1,4 = (8.988*10^9 N*m^2/C^2)(2.00*10^-9)*((2.00*10^-9)/(0.01m)^2)
= 3.595 * 10^-4 j
F2,4 = same
F3,4 = (k*q1*q2)/(r(2,4)^2)*r(3,4)
r(3,4) = r(3,1) + r(1,4) = (0.01m)i + (0.01m)j
r(3,4) = (0.01m)i+(0.01m)j/(sqrt(0.01m^2+0.01m^2)) = 0.14i + 0.14j
F3,4 = (8.988*10^9) (-2.00*10^-9)(2.00*10^-9)/(0.01sqrt(2)^2)*(0.14i+0.14j)
= -2.52 * 10 ^ -5
(3.595 * 10^-4) i - (-2.52*10^-5) i = 3.34*10^-4i <--- Wrong :(
(3.595 * 10^-4) j - (-2.52*10^-5) j = 3.34*10^-4j <--- Wrong :(
Any suggestions?? I think that somewhere in computing F3,4 I put in an incorrect number. Thanks!
Check this.
Whoa, got .707 now, thanks. So then is everything else correct?
= 3.595 * 10^-4 j
Did you use the correct value for q4 here?
