Throw a ball up how high does it go
  • Thread starter Thread starter Zacthor
    Ball
An object projected upward at 2.98 km/s will reach a maximum height where gravitational potential energy and kinetic energy balance. The initial kinetic energy can be expressed as (1/2 mv^2), while the potential energy at height h is approximated as mgh for small heights. However, at this speed, the change in gravitational force becomes significant, requiring the use of the formula for gravitational potential energy, -GmM/r. The discussion emphasizes that the height reached will affect the gravitational pull experienced by the object. Understanding these energy transformations is crucial for accurately calculating the maximum height.
Zacthor
An object is projected straight upward from the surface of Earth with an initial speed of 2.98 km/s. What is the maximum height it reaches?
Ok i know this seams like a really easy problem but i can't figure it out... since this question is from our chapter on gravity i have trued usuing is ke initial = potential energy final...
ke initial being(1/2 m v^2) and potential energy final being: (GMm/r^2)^1/2 M is the mass of the Earth and m is the mass of the ball
You're not going to throw the ball so high that its distance to the center of mass of the Earth will change by a significant percentage. g is nearly constant. Therefore PE at height h will be mgh.
he said 2.98 km/s. that will get you high enough for g get significantly smaller.
the potential energy for a mass at distance r from the Earth is -GmM/r, if the potential at infinity is 0, so there is both an initial and a final potential energy.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
