Calculating .001^100 on TI-83: Results & Accuracy
  • Thread starter Thread starter CarbonBased
    Ti-83
Calculating .001 raised to the 100th power on a TI-83 results in zero due to the calculator's limitations in handling very small numbers and rounding errors. The calculator interprets the result as negligible, equating it to zero. In contrast, more advanced models like the TI-85 and TI-89 can provide a more accurate representation, showing results in scientific notation. Users seeking precise calculations for extremely small numbers may need to use online arbitrary precision calculators or different calculator models. This discussion highlights the importance of understanding calculator capabilities when performing complex mathematical operations.
CarbonBased
This is probably an ignorant question...but why when I attempt to calculate .001 to the 100th power on my TI-83 does it give me an answer of zero? Is the calculator assuming that the answer is so close to zero that it is negligible? If so, that's probably not the accuracy I'm looking for.
Mathematics news on Phys.org
Yup, the calculator sees it just like a 0. Calculators can't store numbers with inifinite digits, plus you get roundinig erros with very small numbers.
.001 = 10^(-3)
.001^(100) = (10^(-3))^100 = 10^(-300) = 0.000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001
My TI-84+ can't handle anything with exponents greater than 99 or less than -99, probably some sort of memory limitation. I don't think the 83 is any better. You can probably find better arbitrary precision calculators online, or the TI-89 seems to handle this calculation fine. (Although, for something like this, you would just figure it out normally like Diffy did.)
That's interesting. Even in "scientific" or "engineering" mode, the TI83 gives an answer of "0E0".
The TI85 and TI89, however, give "1.00E-300".
Ok...that makes sense. And yea I suppose it's pretty simple to work out mentally; I just wanted to diagnose my TI's issues. Thanks for the insight:)
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
