Tick Bite? Red, Swollen Bump on My Side
  • Thread starter Thread starter totallyclueless
The discussion revolves around a user who suspects a tick bite after returning from camping, describing a red, swollen bump with blood in the center. Participants emphasize the importance of proper tick removal techniques, advising against pulling on ticks, which can leave parts embedded in the skin and increase infection risk. They suggest using fine-tipped tweezers to remove ticks, and warn about potential allergic reactions or infections if parts of the tick remain. The possibility of a spider bite is also mentioned, particularly due to the description of the bump. Users recommend monitoring the area for worsening symptoms, such as increased redness, fever, or joint pain, and suggest seeing a doctor if these occur. Overall, the consensus is to keep the area clean and seek medical advice if symptoms escalate.
totallyclueless
I just got back form camping. I think I have been bitten by a tick but I'm not sure. I have a red, swollen, painless bump on my side. It has blood in the middle and is surrounded on the bottom by darker red. It doesn't hurt or itch or anything. I don;t know what to do. I washed it in alchohol and tried to pull the tick out, but I can't actually see the tick. I don't know what it is. Does anyone know? Thanks! I don't want to get a disease...
Do what I always do. Squeeze it! If no pus comes out, squeeze it more, and then some more. If it still doesn't work, get the needle-nose pliers on it...
Or wait for a girly doctor type to get here and tell you what really to do. :smile:
Ticks don't let go until they're done feeding, which can take days. Some ticks are very small, but you should still be able to see it. Sometimes people pull on ticks, or rub the bite, and actually sever the tick's head from the body, leaving the head embedded in the skin. (This is why you should never, never pull on ticks -- you have to make them let go first, then pull them off.) It's possible you have the tick's head still embedded in your skin, and you're suffering an allergic reaction to it.
It's also possible that you got bitten by a spider -- the "blood in the center" part of your description makes it sound like a necrotic ulcer, an area of tissue that was killed by the spider venom.
Going to see the doctor would always be a good idea, but if it doesn't continue to get worse, it's probably nothing to be concerned about.
- Warren
Could have been anything that bit you. Ticks don't burrow under the skin, so if you don't see a tick, there's none there (even little deer ticks are easy to see once they've filled their bellies). If you were in an area where tick-borne diseases are common, get it checked out (and keep an eye on it...if the redness worsens or spreads, it can be a sign of infection; if you're in an area where Lyme disease is prevalent, watch for that characteristic bullseye shape to develop or if you feel any unusual fevers or aches and pains in your joints over the next month or so, see a doctor and let them know you suspect you may have had a tick bite).
Edit: I see Chroot chimed in while I was replying. His comment about the tick's head possibly being left behind if the rest of the tick was rubbed off when you didn't notice is valid, though it would likely be itching or sore if you had something in there causing infection/irritation.
You should not make a tick let go first, you don't want it to inject anything into your skin. The best thing to do is get some tick-tweazers and pull the thing right out in a slightly twisting motion. Don't ever put alcohol or butter on it to let the tick go, it will increase your risk of getting lyme disease. You SHOULD disinfect the area after the tick has been removed.
It could be a bite to which you developed an immune response, watch that the spot does not get bigger (as Moonbear said) and you'll be fine. Go see a doctor if you trust it, it's hard to give advice without actually seeing the rash :)
I agree with Chroot that it sounds like a spider bite. If there is NO sensation in the inflamed area, you need to get to a doctor, no kidding.
Thanks a lot peeps! I thikn I'll put some Neosporin on it and see how it looks in the morning.
if you get pains in joints and such, fever, loss of feeling in the area, or a worsing of the condition, see a doctor.
if nothing happens like above, then don't worry about it, its probably something harmless. may i suggest www.webmd.com you may find some useful things there (i am no doctor, i just do a lot of woods stuff)
Fibonacci
At first I was going to say chiggers and recommend campho-phenique but Chroot bringing up spider bite made me lean more that way(and shudder). BTW, with ticks and chiggers campho-phenique is the best. Beats the heck out of a smoldering match-head or 'baccy juice like Mom used to suggest, PLUS you smell real cool after you use it.
It could be chiggers. I've been fortunate enough to never have them myself, but others have claimed that finger nail polish applied on the bump kills them.
I've pulled ticks off of my uncles dog several times. I've never torn their heads off. (The ticks or the dogs.) If you pull slowly they shouldn't be a problem.
I got Rocky Mountain Spotted fever from a tick bite when I was 11, that was a bad 6 months. :frown:
I got plenty of tick bites when I lived in Jersey. Tweezers always did the trick.
28K
