Time dilation and length contraction
AdamBenHamo
I've recently been thinking more about special relativity, and while I understand the Lorentz factor and how to apply it to find correct solutions, I'm still stuck on the link between the effects of length contraction and time dilation, are they permutation of the same thing from different reference frames? How do they link together mathematically? Any light shed on this at all would be really helpful! Thanks in advance!
AdamBenHamo
AdamBenHamo
It's not just the Lorentz factor that you need to use to find correct solutions, it's the Lorentz Transformation that will link them together mathematically.
Thankyou ghwellsjr, but that doesn't quite answer my question, it's no so much the solutions that I have a problem finding, but the symmetry between the two phenomena that I can't quite get my head around!
Drawing a spacetime diagram helps a lot. Have you done that or have you studied the threads where I have done it?
The muon lifetime measurements are a good way of seeing the relationship. You could try #27 in this fairly recent thread: https://www.physicsforums.com/showthread.php?t=679937
AdamBenHamo said:
...on the link between the effects of length contraction and time dilation, are they permutation of the same thing from different reference frames? How do they link together mathematically?
I'd agree they are permutations of an interval.
length / time = speed
speed is limited, the limited speed is invariant. Lower speeds are not invariant.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
