Time Dilation & Bosons: Decay Rate Changes?
The discussion revolves around the potential effects of material interactions on the decay rates of bosons capable of pair production, particularly in the context of time dilation. Participants explore the relationship between particle decay, interactions with materials, and relativistic effects, with references to both classical and quantum mechanical perspectives.
  • Some participants question whether the decay rate of bosons can be altered by passing through material, suggesting that interactions with the medium could hypothetically affect the particle.
  • One participant argues that there is no evidence to support the idea that such interactions would change decay rates, emphasizing that any potential effect would not be related to relativistic time dilation.
  • Another participant discusses the classical and quantum mechanical explanations for light slowing down in a medium, noting that this involves interactions with the electromagnetic fields of the medium.
  • It is suggested that interactions with matter could change the available decay channels and their cross-sections, complicating the separation of these effects from relativistic considerations.
  • A later reply mentions the use of relativistic quantum field theory (QFT) to understand the properties of photons in a medium, referencing specific literature for further reading.
Participants express differing views on the relationship between material interactions and decay rates, with no consensus reached on whether such changes are meaningful or supported by evidence.
Participants acknowledge the complexity of separating effects due to material interactions from relativistic effects, and there are unresolved assumptions regarding the nature of these interactions.
Andrew Wright
Hi,
It is easy to find discussions about time dilation and muon Half-Life. Is it meaningful to discuss whether bosons capable of pair production can have their decay rate changed if they pass through material?
Andrew Wright said:
it meaningful
I didn't understand what you said, so probably not.
Andrew Wright said:
time dilation
What does passing through a material have to do with time dilation?
One could imagine some physical interaction between particle and medium which affects the particle in some way. However there is zero evidence or reason to think that such a hypothetical interaction might change the decay rate…. and even if such a thing were possible it would be unrelated to relativistic time dilation. An easy way to see this is to use a frame in which the particle is at rest and the medium is moving - there is no time dilation in that frame.
I was thinking of light slowing down when it passes through a medium. People have told me that this is due to interactions that happen to bend and slow the light. It feels odd that a bunch of particle interactions happen to make light refract like a water wave. It always felt like it should not just pop out of particle interactions because it looks like wave behaviour.
If you're talking classically, light is slowed and refracted because it's an EM wave and it interacts with the EM fields of the medium. If you're talking quantum mechanically I think that basically the same thing is true; it's a mistake to think of a photon as a pointlike particle because it has no position operator - it's always spread out and wavelike. But you should probably wait for an answer from someone who's a bit better at QFT than me!
In terms of entering the medium changing decay rates, I'd think that the interactions with the matter change the decay channels available and their relative cross-sections anyway, and it would be hard to separate that from any supposed relativistic effects.
Indeed, you can just use relativistic QFT as well in many-body theory. You get the "properties of an in-medium photon" through calculating the self-energy (or propagator) in the medium. For a very good introduction to this physics, see
J. I. Kapusta and C. Gale, Finite-Temperature Field Theory;
Principles and Applications, Cambridge University Press, 2
edn. (2006).
or
M. LeBellac, Thermal Field Theory, Cambridge University
Press, Cambridge, New York, Melbourne (1996).
  • · Replies 27 ·
  • · Replies 21 ·
  • · Replies 26 ·
  • · Replies 18 ·
  • · Replies 63 ·
  • · Replies 16 ·
  • · Replies 34 ·
