Time Dilation: Understanding the Formula
The discussion revolves around the time dilation formula in the context of special relativity, exploring its implications and the potential for misuse. Participants express varying levels of understanding and propose alternative approaches to the concept.
  • Exploratory, Technical explanation, Debate/contested
  • Some participants express confusion about the time dilation formula, questioning whether a result closer to 1 indicates that time has slowed or increased.
  • Several participants recommend using the Lorentz transform instead of the time dilation formula, citing concerns about potential misuse.
  • One participant argues that while the Lorentz transform is safer, the time dilation formula can provide better physical intuition about how time behaves in different frames of reference.
  • It is noted that a clock moving in a given inertial frame appears to run slower, with a specific example given where a gamma factor of 1.25 indicates that the moving clock ticks slower than the observer's clock.
  • Clarification is provided that a gamma factor of 1 means the clock is at rest relative to the observer, ticking normally.
Participants do not reach a consensus on the use of the time dilation formula versus the Lorentz transform, indicating a debate over the best approach to understanding time dilation.
Some limitations include the potential for misunderstanding the implications of the time dilation formula and the varying interpretations of the gamma factor in relation to time perception.
lewis1440
I do not fully understand the time dilation formula, if the answer is nearer to 1 does that mean time itself under perspection has slowed or increased?
I would recommend not using the time dilation formula. It is too easy to misuse. Instead, you should always use the Lorentz transform.
ok, thankyou.
While it's safer to use the full Lorentz transform, IMO the time dilation formula can give better physical intuition if you're trying to picture how things are behaving in a given frame. It's always true that a clock which is moving in a given inertial frame is running slower in that frame, so for example if gamma=1.25, that means in the frame of the observer who sees the clock in motion, it takes 1.25 seconds for the clock to tick forward by 1 second. So the larger the value of gamma, the slower the clock is ticking in the observer's frame. If gamma=1, then that means the clock is at rest relative to the observer, and it's ticking at 1 second per second of time in the observer's frame (no relativistic time dilation).
  • · Replies 53 ·
  • · Replies 17 ·
  • · Replies 79 ·
  • · Replies 46 ·
  • · Replies 54 ·
  • · Replies 16 ·
  • · Replies 58 ·
