Time Dilation: Relativity's Surprising Effect
Holocene
Time dilation?
Relativity states that it's possible for a clock to run slower the closer it is to a gravitational field.
Basically, a clock at the top of a water tower will run faster than an identical clock at the base.
But aren't the clocks just simple instruments, that will run at the exact same speed regardless of their location?
Perhaps my web page on gravitational redshift can help since these are the same phenomena, See -
http://www.geocities.com/physics_world/gr/grav_red_shift.htm
Any questions, as I'm sure they will be, ask away. :smile:
Pete
Yes! A clock has no idea what altitude it is at and if you go look at the clock, you won't notice anything unusual about it's tick rate. Yet Relativity still is...
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
