Time domain noise from spectral density
daudaudaudau
Hello. Say I have a given noise spectral density and I want to plot the random noise signal arising from this spectral density in the time domain. How can I generally accomplish this? For white noise, I would just pull numbers from a normal distribution, but I don't know what to do for non-white noise.
Best regards
I can't remember all the details. The noise can be generated from a normal distribution, but there is a time correlation (Fourier transform of the spectrum) between samples at different times.
In general the Fourier transform of the spectrum gives you the autocorrelation function. It is not so easy to figure out what sort of process will give rise to this autocorrelation function, though. If you have more information beyond just the spectrum (such as if the process is Gaussian) then you can do more.
jason
What about making a filter, that has the same transfer function as the noise spectral density and then passing white noise through this filter? So if the spectral density is flat, you just get white noise again, if the filter is 1/f you get more low frequency content and less high frequency, and so on ... ?
If you know that your noise is Gaussian then that is the correct thing to do; if your noise is not Gaussian then it is NOT the correct thing to do. That is what I was referring to above - it depends upon what you know about this process.
EDIT: I was sloppy in the above. If you know what sort of process this is (for example, Gaussian), you can make white noise then filter, just like you stated.
Hi all, I've been a roulette player for more than 10 years (although I took time off here and there) and it's only now that I'm trying to understand the physics of the game. Basically my strategy in roulette is to divide the wheel roughly into two halves (let's call them A and B). My theory is that in roulette there will invariably be variance. In other words, if A comes up 5 times in a row, B will be due to come up soon. However I have been proven wrong many times, and I have seen some...
Namaste & G'day Postulate: A strongly-knit team wins on average over a less knit one Fundamentals: - Two teams face off with 4 players each - A polo team consists of players that each have assigned to them a measure of their ability (called a "Handicap" - 10 is highest, -2 lowest) I attempted to measure close-knitness of a team in terms of standard deviation (SD) of handicaps of the players. Failure: It turns out that, more often than, a team with a higher SD wins. In my language, that...
