Time of closest approach between two particles
42 replies · 7K views
Davidllerenav
Two objects ##1## and ##2## move at constant speeds ##v_1## and ##v_2## along of two mutually perpendicular lines. At the moment ##t = 0## the particles are located at distances ##l_1## and ##l_2## from the point of intersection of the lines. At what time will the two objects have a minimum distance? And
what is its expression?
None
I tried solving this using Galilean transformation. So I set the coordinate system on de first object, like this.
cURo0FY
Then. I ended up with something like this.
OldnRnv
After that, I calculated ##\sin \theta = \frac{min}{d}## thus ##min=d* \frac{v_2}{\sqrt{v_1^{2}+v_2^{2}}}##. Am I right?
Only see [IMG} twice. The other (below) is unexeplained (what is v2/1 ?).
I find it hard to believe d is not depnding on l1 or l2
Yes, sorry. That's why I put two links. This is the firts one.
It is the velocity vector of the second object with respect to the first one.
None
cURo0FY
OldnRnv
I am not able to figure out what your second diagram represents or how you arrive at it.
What is d? Only the given variables should appear in the answer, and it should be symmetric between the subscripts 1 and 2.
haruspex said:
Then it points in the wrong direction. It looks more like their sum.
Yes, I know. In class we did something similar. We set the coordinate system on the first particle, so its velocity would be applied on the other particle, but with oposite direction.
Davidllerenav said:
Yes, I know.
No matter, it can be fixed by making the v2 vector point down instead. But I still do not understand the diagram. Please reply to post #4.
Instead of a diagram using relative velocities, you could simply write down the equation for the vector of their relative positions and minimise its magnitude, but I guess you are trying to use a method you have been taught.
I arrived at it by setting the coordinate system on the first particle, so its velocity would be applied on the other particle, but with oposite direction. d is the distance between the particles at the beginning.
How can I solve this usign relative velocity? And how can I solve it without using relative velocity?
TSny said:
@Davidllerenav , In your diagram in post #1 you have the direction of V1 parallel to the initial separation d. I don't think that would generally be a valid assumption.
Yes, I think that was why I could not interpret it. There is a confusion between representations of displacements and representations of velocities.
Sorry if I messed it up. How can I solve this correctly?
haruspex said:
You need to find the direction of the relative velocity vector in relation to that of the initial relative position vector.
I will end up with a triangle, right?
haruspex said:
Yes, but the angle will depend on both the velocity ratio and the ratio of the initial distances.
What do you mean by velocity ratio and ratio of the inicial distances?
In your earlier diagram you had tan(θ) as the ratio of the velocities, v1 and v2. If you forget the velocities and just draw a diagram of the initial positions you will see an angle whose tangent is the ratio of l1 to l2.
The diagram you need makes everything relative to one of the objects, object 1, say. There will be the initial vector position of object 2 relative to object 1, and the velocity vector of object 2 relative to object 1. The angle you need is the angle between these two vectors.
haruspex said:
In your earlier diagram you had tan(θ) as the ratio of the velocities, v1 and v2. If you forget the velocities and just draw a diagram of the initial positions you will see an angle whose tangent is the ratio of l1 to l2.The diagram you need makes everything relative to one of the objects, object 1, say. There will be the initial vector position of object 2 relative to object 1, and the velocity vector of object 2 relative to object 1. The angle you need is the angle between these two vectors.
I tried doing it like this. I don't know if I'm right. In case I'm wrong, could you please show how to do it correctly?
I refuse to look at picures on a site that wants to cookie me and then deletes the picture after a while, so that the thread becomes worthless. PF should ban imgur and the like. If you can upload to them, you can upload directly to PF too.
Here it is.
Better :smile:
but mysterious to me.
The arrows are all over the place
What's 1 and 2 if ##l_1## and ##l_2## are at the curly brackets ?
and where are the angles @haruspex mentions ?
What's 1 and 2 if ##l_1## and ##l_2## are at the curly bracjeets ?
1 and 2 are the object 1 and object 2.. ##l_1## and ##l_2## are the distances that the particles are at time ##t=0##. I don't know which are the angles. How would the correct diagram be?
Your idea of switching to the rest frame of one of the particles is a nice approach.
I have particle 1 as moving up the y-axis, instead of particle 2. But, you can make the necessary adjustments. You should be able to get the distance of closest approach by simple geometric constructions and some trig. Note that the angle θ and the magnitude of v2/1 are determined by v1 and v2.
BvU said:
Giving it away, eh :wink: ? But: beautiful graphics :cool: !
Yeah, when the number of posts gets fairly large (over 20 now), then I tend to give in some. Hope I'm not violating PF rules. But thanks for the comments.
TSny said:
YYou should be able to get the distance of closest approach by simple geometric constructions and some trig. Note that the angle θ and the magnitude of v2/1 are determined by v1 and v2.
Ok, so the distance between the two objects would be the magnitude of the vector from 1 to 2, right?
And I find the magnitude like this: ##|\vec r| = \sqrt{(\vec r_1)^2 +(\vec r_2)^2}##, and each vector would be equal to: ##\vec r_1 = (-l_1 + v_1*t)\vec j## and ##\vec r_2 = (-l_2 + v_2*t)\vec i##, right?
Yes. But you are only looking for the minimum distance between them. In the figure on the right in post #23, can you draw the line of motion of 2 in this frame of reference? Can you identify the point on the line of motion that corresponds to the minimum distance between them?
