Time & Relativity: Grasping the Inconceivable
  • Context: Graduate
  • Thread starter Thread starter laforge
    Relativity Time
The discussion centers around the concept of time in the context of relativity, specifically addressing the synchronization of clocks when one clock travels at a significant fraction of the speed of light. Participants explore the implications of time dilation and the effects of acceleration on time measurement, as well as the nature of time as perceived in different reference frames.
  • One participant struggles with the idea that a clock on a spaceship traveling at 0.5 times the speed of light will show a different time than a stationary clock on Earth upon return, questioning the mechanics of clock function at high speeds.
  • Another participant suggests that time should not be viewed as universal and individual, arguing that the clock on the spaceship experiences time differently due to its speed, resulting in less elapsed time compared to the Earth clock.
  • A participant raises the question of whether the experiment should be considered from a single reference frame, noting that their teacher mentioned the deceleration of the ship affects the application of relativity laws during the turnaround phase.
  • One participant provides a visual representation of clock ticks, indicating that the rate of ticks decreases with speed, illustrating the concept of time dilation.
  • Another participant attempts to reconcile the views of the original poster and their teacher by explaining that clocks measure proper time along their paths through spacetime, suggesting that different paths result in different time measurements, akin to odometers measuring distance.
Participants express differing views on the nature of time and the implications of relativity, with no clear consensus reached. Some agree on the concept of time dilation, while others question the interpretation of clock synchronization and the role of acceleration.
Participants highlight the complexity of understanding time in relativity, noting that assumptions about time being universal may not hold true in different reference frames. The discussion also touches on the effects of acceleration during the turnaround of the spaceship, which remains unresolved.
laforge
Ok in my class we just started reviewing relativity and I had a really hard time grasping it. My teacher says that time moves slower as you get closer to light speed, which I understand because time is kind of a made up variable (right?).
The one thing I really have a hard time understanding is this. Imagine two clocks, one on Earth and one in a spaceship. The spaceship travels at 0.5 x the speed of light and travels far out into space and comes back. Why when the clock in the spaceship comes back it becomes unsynchronized with the clock that was stationary on Earth.
From my understanding the physical mechanics in the clock stay the same no matter how fast or far it travels. So even if it goes the speed of light for a really long time the second hand of the clock will still move forward every second. So even when it comes back, taking out any variable of part failures, the distance the hands of the clock moved should be the same. My teacher says different though.
Can anyone help?
You are thinking of time as 2 fold instead of one. You are saying that time is universal and individual (One overall and one for the clock) this is not the case. The hands on the clock are slowed proportionally to the closeness to light speed. So when you arive back on Earth your clock had had less time to move so actually the counterpart is different then the one in space.
So I should be thinking of the experiment in one reference frame? And not a separate one for each?
My teacher also said it had something to do with the deceleration of the ship for it to turn around and come back. He said that relativity laws don't work during that time interval. Is that correct?
an event is 'o'
a tick is '|'
earth clock ticks:
o o o o|o o o o|o o o o|o o o o|
spacecan clock ticks (@ .6c) :
o o o o o|o o o o o |o o o o o|
the rate of ticks decreases with speed.
Actually, both you and your teacher are correct. One of the key ideas that comes out of relativity is the idea that space and time are not separate things, they are just different directions in a combined thing called spacetime. A correctly functioning clock always correctly measures proper time along its own path through spacetime, but some paths are different lengths than others.
Here is an analogy, a clock measures the distance of a path through spacetime in the same way that an odometer in a car measures the distance of a path through space. If you and a buddy both drive from LA to NY, but you drive through Denver and your buddy drives through Dallas then when you meet up at NY your odometers will have different readings. Both odometers correctly measured the distance along two different paths to the same location. This causes no great intellectual effort to understand because we are used to the fact that "north" and "east" are not really separate things but just different directions in the same space. In a similar way seconds and meters are not really separate things but just different directions in the same spacetime.
The only real difference is that the odometer going straight from A to B reads the shortest distance possible and the clock going straight from A to B reads the longest proper time possible. Thus a "moving" clock accumulates less time than a "resting" clock and therefore can be said to be slow, when all that is really happening is that the "moving" clock is taking a shortcut through spacetime. So both you and your teacher are right in some sense.
  • · Replies 26 ·
  • · Replies 29 ·
  • · Replies 33 ·
  • · Replies 43 ·
  • · Replies 16 ·
  • · Replies 65 ·
15K
