Comp Sci To write a C++ program to find the factorial of a number
The discussion focuses on writing a C++ program to calculate the factorial of a number, highlighting several coding errors in the user's initial attempts. Key issues include syntax errors, such as mismatched parentheses and incorrect use of `cin` and `cout`, which prevent the code from compiling. Participants emphasize the importance of compiling code before seeking help and suggest using `std::cout` instead of `using namespace std;` to avoid potential issues in larger projects. Additionally, a problem with input handling in a separate code snippet is identified, where incorrect array indexing leads to input being ignored. Overall, the conversation provides constructive feedback on improving coding practices and debugging techniques.
Urmi Roy
To write a C++ program to find the factorial of the number input 'a'.
the factorial evaluated is denoted as 'f'
i is the counter
Pls check if my program is correct...(here f is the value of factorial and a is the number whose factorial is to be found...)
#include<iostream>
int f
int a
int i
void main()
{cout<<"Enter a number:<<a;
cin>>a;
for(i=0,i<a;i++)
{f=a;
f=f*i;
cout<<f;
end1
Please tell me if this is okay.
No, it's not OK. The code you posted doesn't even compile. Even after you fix the syntactical errors, it won't print a!.
Considering this question is under 'homework help', some constructive feedback from ppl who are more adept with C++ would be more helpful than just a discouraging statement.
Have you tried to compile your program? What kind of error messages did you get?
Also, is what you typed in the opening post an exact replica of the code you are trying to compile and execute, or did you rewrite it for this thread? There are a number of syntactical errors in what you wrote. If your code does compile, please post that code (e.g., copy and paste) rather than retyping it.
I haven't even got C++ on my computer...this was homework from where I'm taking C++ coaching (only just begun, as you can well imagine)...my teacher asked me to write a code and show him..
How about this...
#include<iostream>
void main()
int f;
int a;
int i;
f=1;
i=2;
cout<<"Enter a number:'<<a;
cin>>a;
for(i=2,i<a;i++)
f=f*i;
cout<<f;
return0
At first sight - it still won't compile. Curly parentheses are not matched. " and ' don't match. No such thing as return0. Please TRY to compile your code before posting it here, otherwise this thread is a waste of time.
BTW, there are many free C++ compilers out there for download for any platform/OS. If you're using Linux or some Unix (including OS X), you probably have it already installed, and accessible through the terminal. So there is absolutely no excuse for not attempting compilation before posting here.
Syntax errors should, at a minimum, be completely fixed before posting to ask for help. Posting to clarify the program flow because the output is not as expected - now that's far more reasonable.
Urmi Roy said:
How about this.
You need to add this line:
just after the #include <iosream> would be ok. This line is needed or else you have to use std::cout and std::cin instead of cout or cin.
you need to remove the << a from this line, since cout is used to output data, and at this point in your program, 'a' is not initialized (no specific value has been stored in 'a yet).
This part of your program is getting close, but it needs a minor fix.
for(i=2,i<a;i++)
f=f*i;
If you have windows, you can download visual c / c++ 2010 express for free. There's also visual studio express 2012, but that needs windows 7.
My advice: Don't ever do that. Not ever. It's a bad habit and it will get you in trouble. Put that in a header file and it will get not only you but everyone who includes that header into trouble.
It's not just my opinion. Programming standard after programming standard prohibits the use of "using namespace xxx" no matter what that xxx is.
There was no mention of putting "using namespace xxx" into a header file, perhaps you had a different point to make here?
Yeah. Use std::cout, std::sqrt, std::this, std::that. It's five extra characters that will save your life. Remember the adage "Always program as if the person who will maintain or use your code is a homicidal maniac who knows where you live."
OK, I got visual C++ (actually visual studio 2008) , and here's a code that does compile, and gives no errors. However, the problem is that after I enter my name, it displays 'Enter your age:' but does not take any input.
Pls provide some feedback.
#include<iostream>
#include<conio.h>
class customer
{ char name[30];
int age;
public:
void accept()
{cout<<"Enter name : ";
cin>>name[30];
cout<<"Enter your age : ";
cin>>age;
void main()
{customer obj;
obj.accept();
getch();
cin>>name[30] is a bad statement. You are supposed to use only cin>>name.
The reason for that is name[29] is the last allocated byte for the variable. name[30] might point to garbage or nothing at all.
Sure, here's some. When you post code here at Physics Forums, put a [code[/color]] tag at the top and a [/code[/color]] tag at the bottom. Doing this preserves whatever indentation you started with, and makes your code easier to read.
I have done this below.
Urmi Roy said:
Code:
#include<iostream>
#include<conio.h>
class customer
   char name[30];
   int age;
   public:
   void accept()
      cin>>name[30];
      cin>>age;
void main()
   customer obj;
   obj.accept();
   getch();
Here's what's happening.
name is an array with indices running from 0 through 29.
Program: Enter name :
You: Urmi Roy
The type of name[30] is char, so the statement, cin << name[30]; stores the character 'U' at a location just outside the name array. This is why Millennial said this was a bad statement.
The input buffer still contains the characters rmi Roy, so when the prompt to enter your age appears, none of the characters in the input buffer can be construed to be a number, so your program ignores them, and ends.
