Today I Learned
  • Thread starter Thread starter Greg Bernhardt
7,000 replies · 653K views · last reply
Cosmic rays are quite rare compared to terrestrial radiation, and it is unclear if life can form if there is just this energy source. They are still water-based, and every place with liquid water is considered as place for life already.
BillTre said:
TIL that there are microbes in a South African gold mine can feed off of the effects of radiation on the chemicals around them.
This implies similar organisms could feed off of cosmic rays and could result in expanding the environments where life might be found.
My first thought has been: Wow, wouldn't that be useful for our nuclear waste problem?
Sure, but maybe enough of them could reduce heat and necessary shielding, in the sense of shortening the range of radiation.
They don't violate energy conservation either. The chemical energy they produce is absolutely negligible compared to the overall heat production. And they do not reduce the radiation length. They increase it compared to heavier elements.
Buzz Bloom said:
TIL (actually yesterday) that Stephen Hawking is hawking jaguars.
I heard that the other day, too.
I love Stephen's excuse, as, it sounds so, um, human:
“You all know me as Professor Stephen Hawking, the physicist wrestling with the great concepts of time and space. But there is another side to me that you may not know: Stephen Hawking the actor. I have always wanted to be in a movie playing the part of a typical British villain. And now, thanks to Jaguar my wish has come true.” -Stephen Hawking
Thank you, professor Hawking.
Many of us, are on the other side of the bridge, wanting to be, as brilliant as you.
I have a lifetime gym membership for a fitness center 600 miles away in another state that I haven't been to in years. Every once in a while I check to see if they have expanded to where I live now. TIL that they went out of business two years ago. :wideeyed:
Lucky you, that you hadn't
to find out!
Today I learned the reason patients should take their Coumadin dose in the evening. Makes sense when it was explained.
Re-reading my General Physics book...
I re-learned a useful tip: to keep one hand on my pockets (if I have) when another touches electricity. To avoid electricity from using my body to make ground. It's a little mini section on the book talking about electric hazards. The book is: https://www.amazon.com/dp/0131992260/?tag=pfamazon01-20
Chapter 26.
Sounds like a practical physics book.
Old timey electricians 'feel' first by brushing with the back of their hand or fingers not the front . That's because electric current makes your muscles contract.
If you contact with the back of your hand that'll pull your hand and fingers away from the source. Don't ever touch it so that contracting muscles would wrap your fingers around it for you won't be able to let go.
It's counter-intuitive. We usually feel with our fingertips , but when 'back of the hand' was explained to me by an old lineman it made so much sense i quickly formed the habit.
Maybe that's in your book too.
Anyhow - thanks for sharing. Awareness of details like that saves lives .
old jim
Why should they?
Today I learned that the Chicago Cubs were not the first occupants of Wrigley Field. That distinction goes to the Chicago Whales.
(Whales? in Chicago? o0))
You're not the first who asked:
http://www.lansingstatejournal.com/story/travel/2016/03/31/heres-whopper-whale-watching-lake-michigan/82473438/
aa said:
Why should they?
It's so that if a doctor has to adjust their dose after blood work they can get the correct dose in that same day. Plus, if you take the dose in the morning it will change the INR levels and not reflect a true accuracy of the levels in the blood.
Today I learned (following up something I read online) that my phone camera sees a bit of infrared. In particular, it sees the output from my TV remote control as a purple glow even though I can't see it directly. Apparently the sensors are sensitive to infrared but the camera has a thin filter which is supposed to cut most of it out.
I knew that but had never done a demo. That's pretty neat...
Today I verified that I can see infrared light at 872 nm +/- 40 nm.
I have an underwater camera that I bought 10 years ago, and it has a 12 infrared led illuminator. The camera is sensitive to both visible and infrared light.
I always assumed that the lamps had a broad spectrum, as I could clearly see the light, but today I found out that they don't, with the use of diffraction grating.
There was some argument in a thread several years ago about this: Can you see IR? [2006-2008]
There was much chatter about people who could see such light being mutants, but, it looks as though it's not quite the case.
After much googling, I finally found someone who had done the experiment, and had a reasonable explanation how it works:
The human eye can see 'invisible' infrared light [phys.org Dec 2014]
"The visible spectrum includes waves of light that are 400-720 nanometers long," explained Kefalov, an associate professor of ophthalmology and visual sciences. "But if a pigment molecule in the retina is hit in rapid succession by a pair of photons that are 1,000 nanometers long, those light particles will deliver the same amount of energy as a single hit from a 500-nanometer photon, which is well within the visible spectrum. That's how we are able to see it."​
ps. I used a mercury vapor lamp as reference, as usual. [image]
8 second exposure time.
Very interesting. Presumably this ability to render IR light as visible is not restricted to human retinas? So it might explain why it is that animals in the wild seem to stare towards the 'invisible' IR floodlight of a hidden wildlife IR camera and can be seen to approach warily the fringe of the invisibly floodlight circle of ground.
Today I learned that among Donald Trump's other abilities, he has the power to add floors to an existing building.
http://www.nytimes.com/2016/11/02/nyregion/donald-trump-tower-heights.html
Or take the https://www.trumpinternationalrealty.com/property-gallery/trump-international-hotel-and-tower-new-york, the hotel and residential building on Columbus Circle that was, pre-Trump, the 44-story Gulf & Western office building. Mr. Trump improved the structure so thoroughly that it managed to stretch into a 52-story tower, even though it stayed, strictly speaking, the same height.
Not sure what to think about this.
I used to work in a lab where we used IR of various wavelengths to illuminate biological specimens in microscopes.
The IR penetrated tissue better (deeper into a sample that is) and activated particular fluorescent dyes.
We also had two-photon confocal microscopes that used IR. I was always told that the two photon microscopes required an extremely high photon density to get two photon excitation (the two photons had to be in the same place at the same time (within some small but vague limits)). This was achieved by using pulsed lasers which concentrated the photons into a very small fraction of the overall time and focused the laser beam into a very small dot.
This makes me doubtful that a TV remote could could achieve two photon illumination very efficiently.
On the other hand, some animals can detect a wider ranges of frequencies than humans.
Pit vipers (like rattle snakes) have a unique structure that can detect IR. They don't use their eyes for this, but have sensors in pits that form a very crude pinhole camera. Information from these sensors does get mapped in the optic tectum, a midbrain sub-cortical sensory center where the optic field is laid out in 2D, but with poor resolution.
One problem with my experiment, and the scientist's experiment, is that something is not quite right.
"The research was initiated after scientists on the research team reported seeing occasional flashes of green light while working with an infrared laser."​
Both my camera and I, see red light. So something is not quite right.
Of course, this being the "Today I learned", I was forced to publish my findings too early, as there is no "Over the last week, my experiments have taught me" thread. :biggrin:
I may have to start a new thread. :angel:
Today I learned of IR fluorescence.
For some reason, I was only aware of UV fluorescence.
I am definitely going to have to start a new thread.
OmCheeto said:
That's really cool.
The research was initiated after scientists on the research team reported seeing occasional flashes of green light while working with an infrared laser. Unlike the laser pointers used in lecture halls or as toys, the powerful infrared laser the scientists worked with emits light waves thought to be invisible to the human eye.
Green, light from infrared !
One wonders what else might trigger those photoreceptors.
A common way to "see" near infrared lasers in a lab are materials that absorb two photons and emit one photon at higher energy. That can be green, but it can also be at longer wavelengths (the remaining energy is then lost elsewhere).
jim hardy said:
That's really cool.Green, light from infrared !
Their whole study goes against everything I know about quantum physics.
Which is very close to zero, btw.
Ergo, my crackpot mind suspects: "commingled wave-functions?" :biggrin:
please don't ban me. please don't ban me. :(
TIL that I coined a new term, as Google claims that there are; "No results found for "commingled wave functions"."
I find that odd.
But then again, I'm pretty sure those quantum mechanics probably have a much fancier term.
