Topology Proof: AcBcX, B closed -> A'cB'
FrancisD
Topology Proof: AcBcX, B closed --> A'cB'
Prove:
and where the prime denotes the set of limit points in that set
X\B is the set difference
Theorem:
B is closed <--> For all b in X\B, there exists a neighborhood U of b with UcX\B
Okay, so I am having no problem showing that the set of limit points of B is contained in B, if B is closed. I feel that there must be a way to extend this fact to show that A'cB', but I am not sure exactly how to do this.
From the theorem:
Since B is closed, there exists a neighborhood U of b with UcX\B, for all b in X\B
then, the intersection of B and U must be empty, AND the intersection of B and (U\{b}) must also be empty.
From the definition of limit point, if b is contained in X\B, then b cannot be contained in B'
or, for all x in B', x also is contained in B.
This is where I have gotten stuck.
Could I possibly show that B closed implies A closed, then use the same logic to show that A'cAcB ?
Thanks
Okay, so I was able to prove that if AcBcX, then A'cB'.
Then, A'cB'cB
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
