Torque: Applied Forces Pos/Neg?
5 replies · 5K views
DameLight
Hi,
I have a question regarding the forces applied on an object that create the torque. I understand that the resulting torque is pos if the object turns counter clock wise and is neg if it turns clock wise and that you can also use the right hand rule to find the direction of the net torque.
I found the right answer for my homework by making some of the resulting torques negative, but I don't understand why they are negative.
Particularly one such problem where there is a circle. One of the forces is tangent and pointing up toward the E most point of the circle. The answer needs this to be neg, but the right hand rule makes it pos?
Was I suppose to be looking for the difference in the resulting torques? But that doesn't make any sense since the net torque is the sum of the torques found.
Never assign a negative value to a force when determining the direction of the torque. Use right hand rule, clockwise is plus and counterclockwise is negative, or the other way around if you wish.
Conclusion:
When finding the torque, the magnitude is found through the equation
but to find the direction you must use the right hand rule for each individual torque before finding the net torque. The ones in opposite directions will cancel each other out and then you will use the right hand rule again to find the direction of the net torque.
The key is that you must assign opposite signs to torques on ccw and cw motion. It doesn't matter which sign you use although the convention is that ccw is positive and cw is negative.
Sorry if this is obvious but... It's important not to just memorise that equation but to understand that it comes from the geometry of the situation. What I mean is when presented with a drawing that already has some random angle marked θ do check it's the correct angle to use in the calculation.
Yes, I understand that the angle you need has to be correct in reference with your chosen coordinate system.
