Torque calculation of an vehicle
The torque required to move an 8000 lb vehicle at a speed of 2 ft/sec on cast iron wheels with a steel track is determined by factors such as acceleration and friction. To achieve this speed, a power output of 0.25 hp is necessary for a 5-second acceleration, while a 1 hp output allows for a 1-second acceleration. The calculations involve considering rolling resistance, aerodynamic drag, and inertia. A simulator can assist in visualizing these parameters and their impact on performance.
  • Understanding of torque and its relationship to acceleration
  • Knowledge of power calculations in mechanical systems
  • Familiarity with rolling resistance and friction coefficients
  • Basic principles of motor selection for vehicle applications
  • Research torque calculations for vehicles using formulas linking angular and linear acceleration
  • Explore power requirements for different motor types, focusing on 3-phase motors
  • Investigate the effects of rolling resistance and friction on vehicle performance
  • Utilize simulation tools to model vehicle dynamics and performance metrics
Mechanical engineers, automotive designers, and anyone involved in vehicle dynamics and motor selection for heavy machinery applications.
anoop
hi,
i have 8000 lb machine it has 4 wheels (just like car), i want it to move on 2 ft/sec speed on cast iron wheels with steel track at flat surface. radius of every wheel in 5 inch. what will be the torque required to move this machine?? and what will be the torque on each wheel?? i want to put two motors on two drive wheels... and which type of motor is suitable in 3 phase motors
please help...
thanx in advance
Hello anoop,
torque is needed for acceleration and to overcome friction. Suppose the friction can be neglected for the moment. Then the required torque depends on how fast you want to accelerate the thing to the desired 2 ft/s ! You'll need to look up some formulas to link angular acceleration and linear acceleration.
The size of your motor is determined by the amount of power needed.
The power needed to move your vehicle is the sum of the resistance forces (which equal the force at the driven wheels) times the speed of the vehicle. Some power will be lost in the transmission due to friction (Even if your motors are connected directly to the wheels, there is the wheel bearing's friction to consider). This transmission loss is usually estimated as a percentage of the input power.
The resistance forces are the following: Rolling resistance, aerodynamic drag force and the inertia (mass X acceleration. Not present when speed is constant).
The maximum constant power output (assuming an adequate torque output vs speed), will also dictate an appropriate time to reach your 2 ft/s (i.e. acceleration desired).
Using this simulator, assuming an 8000 lb vehicle with a 0.75 friction coefficient and a 0.004 rolling resistance, you get a 0-2 km/h (≈ 2 ft/s) in about 5 s with 0.25 hp at the wheels and a top speed of 4 km/h (At this speed, drag and weight distribution is pretty much irrelevant, unless something is really out of the ordinary).
If you want to do it within 1 s, you need 1 hp (which could also give you a 17 km/h potential top speed if power is delivered appropriately).
  • · Replies 58 ·
  • · Replies 19 ·
  • · Replies 18 ·
