Torque from a frame of reference
Defining torque from a frame of reference does require the frame to be inertial for the standard equation ##\vec \tau = I\vec\alpha## to hold true. In a non-inertial frame, such as an accelerating car, pseudo forces must be considered, complicating the torque calculations. For example, while sitting in an accelerating car, the torque needed to maintain balance is influenced by the acceleration of the frame. Therefore, when analyzing torque in non-inertial frames, adjustments must be made to account for these pseudo forces. Understanding this distinction is crucial for accurate torque analysis in varying frames of reference.
SDewan
Whenever we define torque from a frame of reference, is it necessary for the frame to be inertial?
Please explain because I am unclear on this.
Yes. In e.g. an accelerating frame of reference you no longer have ##\vec \tau = I\vec\alpha##.
Example: you sit in an accelerating car and have to lean forward to stay sitting upright. ##\alpha## of your head w.r.t. your hips is zero but you (or the backrest) do have to exercise a torque to stay with your head above your hips.
In case of non inertial frame, a pseudo force should be taken and then we can proceed writing the torque. Right?
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
