Solve Torque Q1: Find Tension & F in Picture Frame
  • Thread starter Thread starter poloboy
    Torque
The discussion focuses on solving a torque problem involving a uniform picture frame weighing 10N, supported by a cable at a 50-degree angle. The key equations derived include the X-component: fcos50 - F = 0 and the Y-component: fsin50 + f(left) = 10. The recommended pivot point for calculating torque is the upper right corner of the frame, simplifying the equations by eliminating trigonometric functions.
  • Understanding of torque and its calculation
  • Knowledge of force components in physics
  • Familiarity with trigonometric functions, specifically sine and cosine
  • Basic principles of static equilibrium
  • Study torque calculations using different pivot points
  • Learn about static equilibrium conditions in physics
  • Explore the application of trigonometric functions in force analysis
  • Practice solving similar problems involving forces and torques
Students studying physics, particularly those focusing on mechanics, as well as educators seeking to enhance their teaching of torque and static equilibrium concepts.
poloboy
1. A uniform picture frame weighing 10N is supported. The cable on the right side makes an angle of 50 with the horizontal direction. Find the tension in the cords and the magnitude of the horizontal force F required to hold the frame in the position
imagine a rectangular box, the length is 0.15m and width 0.3m there is a cord hanging on straight up from the top left of the box and a cord hanging on the top right of the box at a 50 degree angle. Also there is a force F pointint to the left from the bottom right corner
i believe this question is a torque question, but I'm not 100% sure how to start solving. i broke down the equation into X-component and Y-component
X-comp: fcos50 - F =0
Y-comp: fsin50 + f(left) = 10
i'm kinda stuck after this point
i know that torque = Fd but i don't know where my pivot point should be and so on can anyone help. thanks!
You can choose any point for the torque pivot... It's best to choose a point that makes your equations simple...
I recommend the upper right point, because then you avoid having the trig stuff in your equation.
  • · Replies 25 ·
