Solve TOV for Non-Constant Density Star - Friends Help Needed!
shadi_s10
Dear friends,
Does anyone know how we can solve the TOV equations for a non constant density?
In all the references, I just saw the solution for a constant density.
Thanks in advance for the help :)
An equation of state and boundary conditions also are needed. As is often the case with (systems of ) differential equations, few analytical solutions are know. From page 293 of "General Relativity: Am Introduction for Physicists" by Hobson, Efstathiou, and Lasenby:
"Very few exact solutions are known for realistic equations of state, and so in practice the system of equations is integrated numerically on a computer. The procedure is to ‘integrate outwards’ from r = 0 (in practice in small radial steps of size ##\delta##r) until the pressure drops to zero. This condition defines the surface r = R of the star, since otherwise there would be an infinite pressure gradient, and hence an infinite force, on the material elements constituting the outer layer of the star"
Likes bcrowell and Mentz114
George Jones said:
An equation of state and boundary conditions also are needed..."
Thanks for your explanations.
Is using general relativity in order to get to the pressure inside a star OK?
I am doing some calculations and so far I think the gravitational potential would be quit different.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
