Identifying Equivalent Force in New Location: Examples & Solutions
  • Thread starter Thread starter tomallan
    Equivalent Force
Identifying an equivalent force when transferring it to a new location is generally possible, but it depends on the specific context of the force application. For instance, the force required to push a car remains consistent regardless of location, while balancing a seesaw depends on the force's position relative to the pivot. Calculating equivalent forces often involves using moments or equilibrium equations. An example provided illustrates that different lengths of a wrench can require varying forces to achieve the same torque. Overall, understanding the mechanics involved is crucial for accurate calculations.
tomallan
hello. thanks for viewing my post. I want to know if there is a way to identify an equivalent force if I transfer the original force to a new location. is that possible? ill give an example.
position of original force ----------(known distance)--------------------- desired new position of force
do you need to use moments or equilibrium equations. or is it even possible?
It's not possible to answer that without more details of the situation. For example:
If this was the force needed to push a car along a road it might be the same in both places.
If this was the force needed to balance a seesaw (teeter-totter) then it might depend on the position of the force relative to the pivot.
Usually it is possible to calculate the equivalent force. If you wish to apply a torque to a wheel nut you can do it with a short or long wrench. It's relatively easy calculate the different force required on the end of each wrench to achieve the same torque.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
