Struggling with Transfer Functions? Here's How to Improve Your Skills!
Many individuals struggle with deriving transfer functions in electronics, particularly when analyzing complex circuits. A common approach is to utilize Kirchhoff's Current Law (KCL) to set up equations, but confusion often arises regarding the parameters involved, such as open-circuit conditions and node voltages. There is a demand for clear, worked examples to demystify the process, as many learners find existing resources inadequate. Participants in the discussion emphasize the importance of practice and seeking out additional educational materials to enhance understanding. Improving skills in this area requires patience and persistence, along with practical application of the concepts.
bitrex
Hi everyone - I've been self-studying electronics for the past couple years and I have a confession to make: I'm terrible at deriving transfer functions. I'd really like to improve at it, but every time I see a circuit like the following (to analyze for Z parameters, for example) I start to panic. http://en.wikipedia.org/wiki/File:Smal-signal_mirror_circuit.png
Is some trick to go about analyzing a circuit like that? Or just draw up the nodes and try to grind it through with KCL? Any tips on how to get better at this important skill would be appreciated.
There may be some tricks that can help, but I just knee-jerk go straight to the KCL equations.
The problem is with these two-port parameter things I never understand what to calculate - ok I understand I have to for example open circuit I2 in the example to find R21, but how do I calculate the voltage there if that node is open circuited? And what is I1 supposed to be? It's all really confusing. I'm sure if I could see a few worked examples it would make sense, but I don't have a textbook that covers this topic and I've searched the web for hours to no avail. Whatever I do, I can never seem to follow how those complicated expressions for the various parameters are obtained.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
