Archived Transformation of Gravitational to Kinetic Energy
The discussion focuses on the transformation of gravitational energy into kinetic energy for two equal mass particles attracted to each other. The change in kinetic energy is given as 1J, and the final velocity is derived using two approaches, leading to confusion regarding the correct interpretation. The first method correctly accounts for the system's mass, while the second mistakenly treats the masses separately, resulting in contradictory conclusions. The participant clarifies that the kinetic energy change applies to the system as a whole, emphasizing that both particles experience the same change in velocity. Ultimately, the key takeaway is that the mass used in calculations must be consistent to avoid errors in determining the final velocity.
012anonymousx
I am not following the template for the reason that this is a generic question.
Consider that the change in kinetic energy is 1J.
Suppose further you have two particles, both of equal mass that are gravitationally attracted to each other (and the change in energy comes from the fact that they moved closer to each other -- these are planetary objects).
What is their final velocity? Assume they start from rest.
First thing to notice: their velocities will be exactly the same throughout. so (vf)^2 = (-vf)^2 = vf
So two approaches:
dk = (1/2)(m)(v^2)
Rearrange for v and divide by two because the velocity "splits" into two for both the masses.
You will find a factor of root 2 over 2.
Approach two:
dk = (1/2)(m)(v^2) + (1/2)(m)(v^2) = m v^2.
Rearrange for v. Here we have no need for dividing by two, we straight up get the v. This v has no factor infront of it. It is just root of (dk/m).
So two contradicting pieces. The first approach is in fact correct. I have confirmed it.
Can someone point out the flaw in the logic of the other piece?
[EDIT]
Okay I found one mistake in my reasoning:
The change in energy is for the system. I should mention that.
So the way I got it was 2 *(Gm^2/r), r is the distance between their centres. Multiply by two for both.
So the change in kinetic energy of the SYSTEM is actually: (1/2)(2m)(2*vf)^2.
Wait... no okay, I got it! vf of the system has to remain the same. Makes no sense if it changed by conservation of energy.
Thanks for letting me write. I was stuck on this problem for a while!
Assuming both masses are the same, then they will both experience the same change in velocity.
The important thing to note with method 1 is that the mass (denoted as 'm') is the mass of the system, whereas in method 2, the masses (also denoted 'm') are the masses of the 2 individual "particles". 'm' from method 1 = 2x 'm' from method 2.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
