Transformations of free fields
  • Level: Graduate
  • Thread starter Thread starter bartadam
    Fields Transformations
3 replies · 2K views
bartadam
Hi, New here...Can't seem to do latex on here so this post is incomplete until I can work it out.
This is maybe quite abstract and generic, but here goes. This problem has niggled me for a while and I need some input please.
I have an action [tex]S=\int d^4 x \sqrt(g(x))\overline\Phi (x)\Omega(x)\Phi(x)[/tex]
where [tex]\Omega(x)[/tex] is a differential operator and [tex]\Phi(x)[/tex] and [tex]\overline\Phi(x)[/tex] are the free field and it's dual respectively. For example, they may well be scalars [tex]\phi(x)[/tex] and [tex]\overline\phi(x)[/tex] or vectors, or spinnors superfields tensors etc...Any generic spacetime object.
Say for the moment they are scalars and define a transformation of the fields as follows
[tex]\delta\phi(x)=\epsilon\phi(x_G)[/tex] and [tex]\delta\overline\phi(x)=-\epsilon\overline\phi(x_{G^{-1}})[/tex]
where [tex]x \rightarrow x_{G}[/tex] is a finite isometry. Also omega is the operator [tex]g^{\mu\nu}\partial_{\mu}\partial_{nu}[/tex] and is invariant under isometriesThen the change in the action is
[tex]\delta S=\epsilon\int d^4 x \sqrt(g(x))\overline\Phi (x)\Omega(x)\Phi(x_G)-\epsilon\int d^4 x \sqrt(g(x))\overline\Phi (x_{G^{-1}})\Omega(x)\Phi(x)[/tex]
which is zero by changing variables in the second integral and using the fact that x goes to xG is an isometry.
Now, [tex]\delta\phi(x)=\epsilon exp(X^u \partial_{\mu})\phi(x).[/tex]
where X is a killing vector. I know this for a fact because it's just parameterising the isometry and using the chain rule. The each term in the taylor expansion is also a symmetry. I.e, it is the exponential of the directional derivative, defined as it's taylor expansion. It also happens to be the Lie derivative of a scalar field which pertains to something I will say in a while.
Now...I have tried to do this for a vector say [tex]A^{\mu}[/tex] and it's dual [tex]\overline A_{\mu}[/tex]
I am having difficulty deciding what the transformation will be at the moment I have
[tex]\delta A(x)=\epsilon A^{\mu}(x_G) =\epsilon exp(X\partial)A(x)[/tex] and [tex]\delta \overline A(x)=-\epsilon A_{\mu}(x_{G^-1}}) dx^{\mu}=-\epsilon exp(-X\partial)\overline A[/tex]
and then the change in the action is[tex]\delta S=\epsilon\int d^4 x \sqrt(g(x))\overline A_{\mu}(x) dx^{\mu} e_{\nu}(x)\Omega^{\nu}_{\lambda}(x) dx^{\lambda} e_{\sigma}(x) A^{\sigma}(x_G)-\epsilon\int d^4 x \sqrt(g(x))\overline A_{\mu}(x_{G^-1}}) dx^{\mu} e_{\nu}(x)\Omega^{\nu}_{\lambda}(x) dx^{\lambda} e_{\sigma}(x) A^{\sigma}(x)[/tex]
Then perform [tex]x \rightarrow x_G[/tex] on the second integral and [tex]dx_G^{\mu} e_{\nu}(x_G)=dx^{\mu} e_{\nu}(x)[/tex] since it is simply the inner product of basis vectors so gives the delta function. Omega is invariant since it is an isometry, and [tex]\sqrt{g} d^4 x[/tex] is also invariant and so the change in the action is zero. So, again, each term in the expansion of [tex]exp(X\partial)[/tex] is a symmetry.
Now I don't believe this argument for a vector. I think the transformations should include some matrices, and should be the exponential of the Lie derivative of the vector. However, I can't get the argument with matrices to work. I.e. something like this
[tex]\delta A= U^{-1}\epsilon A(x_G)[/tex] where [tex]U^{-1}[/tex] is the matrix that maps basis vectors at [tex]x_G[/tex] back to x. I was hoping this gives the exponential of the Lie derivative, and it doesn't seem to and also the matrices don't all work out when I do the change of variables in the second integral
Is my argument for the vector field reasonable? Have I made a conceptual error? Is it simply the exponential of the normal directional derivative. I don't believe it because I would expect the indices to change.
And how on Earth will this work for more arbitrary space time objects [tex]\Phi[/tex]
Sorry for the long post. I don't think I have made any latex typos
It's [tex]at this site, not [math]. I'm a regular at another vBulletin forum where it's [itex], so it seems to be up to the administrator rather than a vBulletin standard.<br /> <br /> Edit: I see you figured that out. <img src="https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png" class="smilie smilie--emoji" loading="lazy" width="64" height="64" alt=":smile:" title="Smile :smile:" data-smilie="1"data-shortname=":smile:" />[/itex][/tex]
Hi, yeah thanks worked it out, looked on another thread and clicked on some maths to find the code.
Any help much appreciated.
Is my expression for the scalar correct?
[tex]\delta \phi(x)=\epsilon \phi(x_G)=\epsilon exp (X^{\mu}\partial_{\mu})\phi(x)[/tex]
I proved this by having the Killing vector field over the manifold, then parameterising the integral curve x goes to xG, taylor expanding and using the chain rule.
Although I have been reading some riemannian geometry books and this exponential map seems to pertain only to geodesics, and the flows generated by isometries are not geodesics. I don't really understand them though, rather too abstract.
The following might help!
Cosider a spacetime symmetry whose infinitesimal action on the coordinates is given by
[tex]x^{a} \rightarrow \bar{x}^{a} = x^{a} + \delta_{f}x^{a}[/tex]
where
[tex]\delta_{f}x^{a} = -f^{a}(x)[/tex]
contains the infinitesimal parameters. Under such symmetry, a multi-component field transforms as
[tex]\bar{u}_{A}(\bar{x}) = D_{A}{}^{B}(f) u_{B}(x)[/tex]
where D is a finite dimensional (matrix) representation of the group. To 1st order in the parameters, we write
[tex]\bar{u}_{A}(x - f) = \left(\delta_{A}{}^{B} + X_{A}{}^{B}(f) \right) u_{B}(x)[/tex]
or,
[tex]\bar{u}_{A}(x) - f^{a}\partial_{a}u_{A} = u_{A}(x) + X_{A}{}^{B}(f)u_{B}(x)[/tex]
The X's are set of matrices, appropriate for the field, satisfying the Lie algebra of the symmetry group. For scalar field X = 0, and for covariant vector field it is [itex]\partial_{a}f^{a}[/itex].
Thus, the infinitesimal change in the form of the field function is
[tex]\delta_{f}u_{A}(x) \equiv \bar{u}_{A}(x) - u_{A}(x) = f^{a}\partial_{a}u_{A}(x) + X_{A}{}^{B}u_{B}(x)[/tex]
Except for spinor field, [itex]\delta_{f}[/itex] is nothing but the Lie derivative.
regards
sam
