Transistors circuit - Basic questions
  • Context: Engineering
  • Thread starter Thread starter Femme_physics
    Circuit Transistors
96 replies · 15K views
I like Serena said:
A FET is a transistor! :p
FETis Field Effect Transistor, with high input resistance.
The one in the problem is bipolar transistor, and it has low input resistance.
A voltage divider is two resistors in series connected to a voltage source and using the voltage between one end of one resistor and the common point of the pair of resistors. A potentiometer can serve as voltage divider.
ehild
Indeed it can. A potentiometer can serve as a variable voltage divider. :wink:
Potentiometer...not to be confused with a voltmeter...and definitely not to be confused with a voltameter. :shy:
which works on the principle of voltage divider. :rolleyes:
which is definitely not a voltage divider:smile:.
ehild
So I talked to my teacher. He told me that I'm wrong and he doesn't know what I'm talking about and that voltage divider would give me the same result for Ib as Kirchhoff laws. I showed him all my papers trying to prove him wrong but he said I'm not using voltage divider correctly, that I should use the formula
R1 x R2 / R1 + R2
To create a new resistor, RBB, that Ib goes through, and then I can just use this resistor while ignoring R1 and R2. The result that turned up is indeed the same result as Ib with Kirchhoff's...
So I don't see how anything you said make sense if we simply didn't use the right formula.
What a nasty fellow! :smile:
That's because, as I explained, you have been using the phrase "voltage divider" to mean something completely different from the usual meaning. (I think we needn't go over all that again.)
R1 x R2 / R1 + R2
That's what I showed as the Thevenin equivalent, but because you haven't studied that yet, there is no necessity to analyze the circuit that way. Whatever way the circuit is analyzed, if it is valid and is done correctly it will arrive at the same answer. It is all basic mathematics; there is no room for magic or skullduggery. :wink:
Well, it couldn't be called the Thevenin equivalent if it didn't give equivalent results. :cool:
I can't see myself in this picture; I'm sure this must be a reference to some other "you". :-p
So, is it all sorted now? Or (I hesitate to ask) still some confusion? :shy:
Well, he said that HE doesn't know what I'm talking about not that I don't know what I'm talking about. He's ok :)
LOL. All I can do is thank you, you keep me engaged, asking, and curious,and with a supply of intelligent answers. What we did is not called voltage divider then, it's called "Thévenin's theorem", that's the only difference?
Sure don't see myself here, either. Really must be some other "you" this time.
Back in this post I stated that it is possible to view the two resistors between Vcc and ground as equivalent to a voltage source in series with a single resistor. When applied to transistor biasing, as here, that Thevenin voltage source is referred to as VBB. But as someone else had introduced a weird way to name voltage from base to emitter as VBB I didn't compound the confusion by pointing out that's not right and the symbol VBB should refer to the Thevenin base voltage (in precisely the same way that VCC truly does refer to the Thevenin voltage of the collector supply).
I think you should give this topic a rest, and put your energies towards other topics. Come back to this in a few weeks, and with a fresh start you'll wonder how you managed to make such heavy work of it first time around. :cool:
You know enough now to be able to sort it out yourself, just pencil, paper, calculator and Ohms Law, and a quiet location away from distractions. :smile:
