Transitions in diatomic molecules
  • Context: Undergrad
  • Thread starter Thread starter kelly0303
    Molecules
The discussion centers on transitions in diatomic molecules as analyzed through molecular spectroscopy. It confirms that changes in total angular momentum (J) can only be -1, 0, or +1, corresponding to the P, Q, and R branches, respectively, due to the single photon carrying a spin of 1. Multiphoton events, which require larger electromagnetic (EM) fields, are necessary for changes greater than one. The selection rules dictate that transitions must adhere to the conditions of Δl = ±1 and allow for Δm = 0, despite the photon’s polarization components.
  • Understanding of molecular spectroscopy principles
  • Familiarity with angular momentum in quantum mechanics
  • Knowledge of electromagnetic interactions in quantum systems
  • Basic grasp of selection rules in quantum transitions
  • Research the implications of multiphoton events in molecular transitions
  • Study the selection rules for electric dipole (E1), electric quadrupole (E2), and magnetic dipole (M1) transitions
  • Explore the role of angular momentum conservation in quantum mechanics
  • Investigate advanced topics in molecular spectroscopy, focusing on laser-induced transitions
Researchers, physicists, and students in the fields of quantum mechanics and molecular spectroscopy, particularly those interested in the behavior of diatomic molecules under electromagnetic interactions.
kelly0303
Hello! I started reading some stuff about molecular spectroscopy and I see that the changes in the total angular momentum, J, can be -1, 0 or +1 (corresponding to the P, Q and R branches). Is this because the photon carries a spin of 1? Also is this the most general case (assuming only EM interactions), or we can have changes greater that 1 in the J values (but probably very weak)? Thank you!
Changes in total angular momentum of greater than one (or zero) require multiphoton events. Multiphoton events require much larger EM fields and usually result from a tuned and focused laser excitation.
In addition, the Q branch (##\Delta J =0##) is forbidden for diatomics with electronic angular momentum of zero for the same reason (angular momentum conservation).
Thank you for your reply. So for a not intense EM field, a change of 1 is the best you can get, right? What do you mean by "or zero"? Can't you, in general, easily have a change of 1, without violating any conservation?
Yes, single photon angular momentum changes of 1 are allowed. Sorry for the awkward, ambiguous grammar.
Thank you! One more question, can we have transition for which ##\Delta l = 0##? Given that the photon has a spin of 1, and we conserve parity in EM interaction, I assume that we can only have ##\Delta l = \pm 1##. Is this true for all orders in an EM interactions (i.e. E1, E2, M1 and higher)? Also I assume we can have ##\Delta m = \pm 1##, but can we have ##\Delta m =0##? Given that the photon has as polarization components just ##\pm 1## but not 0, I assume that one can't have ##\Delta m =0##. Is that true? Thank you!
Indeed, the selection rule is ##\Delta l = \pm 1##, due to the spin of the photon.
No. The quantization axis is not the same as the direction of propagation of the photon, so ##\Delta m =0## is allowed.
kelly0303 said:
Is this true for all orders in an EM interactions (i.e. E1, E2, M1 and higher)? Thank you!
Things are a bit more complicated when you go beyond the dipole approximation. See
https://jila.colorado.edu/~ajsh/astr5110_13/notes/selec.pdf
  • · Replies 0 ·
