Trapezoidal Rule Homework: Integrate 0 to 2 x^3
  • Thread starter Thread starter mxthuy95
mxthuy95
Determine and evaluate a definite integral for which (1/40( (0)^3 + 2(.05)^3 +2(.1)^3 +... 2(1.95)^3 + (2)^3 )) is a trapezoidal approximation. Which is greater, the integral or trapezoidal approximation why
So i figure that the the original equation is x^3 and the limits are 0 to 2 so i got this integral
∫ X^3 = 4.0025 using trapezoidal rule with n=20 on my Riemann sum program. I said that this is
greater than the actual integral because the graph is increasing and concave up. I check with my
teacher and it was wrong. So where did i go wrong.
Thank you.
I said that [the trapezium approx for ##\int_0^2x^3dx##] is greater than the actual integral because the graph is increasing and concave up.
That's what I'd have said too.
Have you correctly identified the function being integrated?
Have you use the correct reasoning?
... that would be: $$\frac{1}{40}\left (
0^3+2(0.05)^3+2(0.1)^3+\cdots + 2(1.95)^3+(2.0)^3
\right )$$
Compare with the trapezoidal rule:
$$\int_a^b f(x)dx \approx \frac{b-a}{2N}\left ( f(x_1)+2f(x_2)+\cdots +2f(x_{N-1})+f(x_N) \right )$$... I'm having trouble faulting this.
Perhaps the teacher means something else?
" ... with n=20 ..."
n = 40, not 20. That's the only thing I can see.'wrong'.
It could be that simple.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
