Triangular cavity thermal radiation simulation
9 replies · 3K views
FEAnalyst
TL;DR
How to solve this problem involving radiation in a triangular cavity?
Hi,
I'm trying to solve a problem involving radiation in a triangular cavity:
As you can see, lengths and emissivities of all surfaces are given. For two of them, the heat flux is known and the temperature has to be found while for the remaining surface it's the other way around.
I have the numerical and analytical solutions for this problem, but I want to know exactly how to obtain the latter. Here's my approach, based on the book by A. Bejan: $$Q_{1}=\frac{\varepsilon_{1} \cdot A_{1}}{1- \varepsilon_{1}} \cdot \left( \sigma \cdot T_{1}^{4}-J_{1} \right)$$ $$Q_{2}=\frac{\varepsilon_{2} \cdot A_{2}}{1- \varepsilon_{2}} \cdot \left( \sigma \cdot T_{2}^{4}-J_{2} \right)$$ $$Q_{3}=\frac{\varepsilon_{3} \cdot A_{3}}{1- \varepsilon_{3}} \cdot \left( \sigma \cdot T_{3}^{4}-J_{3} \right)$$ $$J_{1}=(1- \alpha_{1}) \cdot \left( (J_{2} \cdot F_{12})+(J_{3} \cdot F_{13}) \right) + \varepsilon_{1} \cdot \sigma \cdot T_{1}^{4}$$ $$J_{2}=(1- \alpha_{2}) \cdot \left( (J_{1} \cdot F_{21})+(J_{3} \cdot F_{23}) \right) + \varepsilon_{2} \cdot \sigma \cdot T_{2}^{4}$$ $$J_{3}=(1- \alpha_{3}) \cdot \left( (J_{1} \cdot F_{31})+(J_{2} \cdot F_{32}) \right) + \varepsilon_{3} \cdot \sigma \cdot T_{3}^{4}$$ where view factors are calculated from the following formulas: $$F_{12}=\frac{L_{1}+L_{2}-L_{3}}{2 \cdot L_{1}}$$ $$F_{13}=\frac{L_{1}+L_{3}-L_{2}}{2 \cdot L_{1}}$$ $$F_{31}=\frac{L_{3}+L_{1}-L_{2}}{2 \cdot L_{3}}$$ $$F_{21}=\frac{L_{2}+L_{1}-L_{3}}{2 \cdot L_{2}}$$ $$F_{23}=\frac{L_{2}+L_{3}-L_{1}}{2 \cdot L_{2}}$$ $$F_{32}=\frac{L_{3}+L_{2}-L_{1}}{2 \cdot L_{3}}$$
The problem is that the software that I use to solve this system of 6 equations for the 6 variables ##J_{1}##, ##J_{2}##, ##J_{3}##, ##Q_{1}##, ##T_{2}## and ##T_{3}## doesn't give any solution so I assume that something is wrong with my equations. Do you know where I made the mistake in the calculations? Maybe I misinterpreted the formulas from Bejan's book. They look like this: $$Q_{i}=\frac{\varepsilon_{i} A_{i}}{1- \varepsilon_{i}} \cdot \left( \sigma T_{i}^{4}-J_{i} \right)$$ $$J_{i}=(1-\alpha_{i}) \sum_{j=1}^{n} J_{j}F_{ij}+ \varepsilon_{i} \sigma T_{i}^{4}$$ for ##i=1,2,...,n## where ##n## is the number of surfaces in a cavity. $$F_{ij}=\frac{L_{i}+L_{j}-L_{k}}{2L_{i}}$$
[EDIT] I've resolved a bug, in the R matrix i used -1 instead of Q2 and Q3[/EDIT]
I don't really know about radiation and so I cannot check the equations themselves. But you can just solve them as a set of 6 linear equations with 6 unknowns. First, to make things a little bit easier, define these constants:
c_x = \frac{\varepsilon_x A_x}{1-\varepsilon_x}
and
\beta_x = 1-\alpha_x
Furthermore I solve for ##T_x^4## because all temperatures enter the equation to the power four, so you don't have to bother with powers of 1/4th and all that. Just do that at the end.
Now you can just rewrite the six equations to set up this matrix equation:
\begin{bmatrix}
c_1 & 0 & 0 & 1 & 0 & 0 \\
0 & c_2 & 0 & 0 & -c_2\sigma & 0 \\
0 & 0 & c_3 & 0 & 0 & -c_3\sigma \\
1 & -\beta_1 F_{12} & -\beta_1 F_{13} & 0 & 0 & 0 \\
-\beta_2 F_{21} & 1 & -\beta_2 F_{23} & 0 & -\varepsilon_2 \sigma & 0 \\
-\beta_3 F_{31} & -\beta_3 F_{32} & 1 & 0 & 0 & -\varepsilon_3 \sigma
\end{bmatrix}
\begin{bmatrix}
J_1 \\
J_2 \\
J_3 \\
Q_1 \\
T_2^4 \\
T_3^4
\end{bmatrix}
\begin{bmatrix}
c_1 \sigma T_1^4 \\
-Q_2 \\
-Q_3 \\
\varepsilon_1 \sigma \\
0 \\
\end{bmatrix}
So I've used a simple bit of octave (Matlab) code to solve all this. I needed specific numbers so I just came up with a few. But you can solve above matrix analytically as well if you want.
[CODE lang="matlab" title="Octave/Matlab"]L1 = 3;
L2 = 4;
L3 = 5;
eps1 = 0.3;
eps2 = 0.5;
eps3 = 0.6;
T4_1 = 200^4;
Q2 = 1500;
Q3 = 2500;
F12 = (L1 + L2 - L3)/2/L1;
F13 = (L1 + L3 - L2)/2/L1;
F31 = (L3 + L1 - L2)/2/L3;
F21 = (L2 + L1 - L3)/2/L2;
F23 = (L2 + L3 - L1)/2/L2;
F32 = (L3 + L2 - L1)/2/L3;
s = 5.670373e-8;
alfa1 = 0.8;
alfa2 = 0.7;
alfa3 = 0.1;
d = 1.2;
A1 = L1*d;
A2 = L2*d;
A3 = L3*d;
c1 = eps1*A1/(1-eps1);
c2 = eps2*A2/(1-eps2);
c3 = eps3*A3/(1-eps3);
b1 = 1-alfa1;
b2 = 1-alfa2;
b3 = 1-alfa3;
M = [
c1 0 0 1 0 0;
0 c2 0 0 -c2*s 0;
0 0 c3 0 0 -c3*s;
1 -b1*F12 -b1*F13 0 0 0;
-b2*F21 1 -b2*F23 0 -eps2*s 0;
-b3*F31 -b3*F32 1 0 0 -eps3*s
R = [
c1*s*T4_1;
-Q2
-Q3
eps1*s
0];
x = M \ R;
J1 = x(1);
J2 = x(2);
J3 = x(3);
Q1 = x(4);
T4_2 = x(5);
T4_3 = x(6);
disp(['J1 = ' num2str(J1)])
disp(['J2 = ' num2str(J2)])
disp(['J3 = ' num2str(J3)])
disp(['Q1 = ' num2str(Q1)])
disp(['T2^4 = ' num2str(T4_2) ', T2 = ' num2str(T4_2^(1/4))])
disp(['T3^4 = ' num2str(T4_3) ', T3 = ' num2str(T4_3^(1/4))])[/CODE]
If I run this, this is the result, for which I have no clue whether it is reasonable or not :):
[CODE title="Solution"]
J1 = 696.1098
J2 = 2258.1934
J3 = 4091.7266
Q1 = -934.0207
T2^4 = 45335526345.2526, T2 = 461.4341
T3^4 = 77058500323.9253, T3 = 526.872
[/CODE]
@Arjan82 Thank you very much. I don't have access to Matlab so I used this code in Scilab. It seems that the equations are correct from the mathematical point of view. I don't know why I wasn't able to solve them in another software.
Anyway, I substituted the input values to your code and the results are close to what I expected but not exactly. Here are the inputs: $$L_{1}=4 \ m, \ L_{2}=3 \ m, \ L_{3}=5 \ m$$ $$A_{1}=L_{1} \cdot 1, \ A_{2}=L_{2} \cdot 1, \ A_{3}=L_{3} \cdot 1$$ $$\varepsilon_{1}=\alpha_{1}=0.4, \ \varepsilon_{2}=\alpha_{2}=0.6, \ \varepsilon_{3}=\alpha_{3}=0.8$$ $$T_{1}=307 \ K, \ Q_{2}=6000 \ W, \ Q_{3}=5000 \ W$$ $$\sigma=5.67 \cdot 10^{-8} \ \frac{W}{m^{2}K}$$ And the results should be: $$Q_{1}=-11000 \ \frac{W}{m}, \ T_{2}=641 \ K, \ T_{3}=600 \ K$$ This Scilab code:
[CODE title="Scilab - input"]L1 = 4;
L2 = 3;
L3 = 5;
eps1 = 0.4;
eps2 = 0.6;
eps3 = 0.8;
T4_1 = 307^4;
Q2 = 6000;
Q3 = 5000;
s = 5.67e-8;
alfa1 = 0.4;
alfa2 = 0.6;
alfa3 = 0.8;
d = 1;
A1 = L1*d;
A2 = L2*d;
A3 = L3*d;
b1 = 1-alfa1;
b2 = 1-alfa2;
b3 = 1-alfa3;
M = [
c1 0 0 1 0 0;
0 c2 0 0 -c2*s 0;
0 0 c3 0 0 -c3*s;
R = [
c1*s*T4_1;
-Q2
-Q3
eps1*s
0];
R
x = M \ R;
J1 = x(1);
J2 = x(2);
J3 = x(3);
Q1 = x(4);
T4_2 = x(5);
T4_3 = x(6);
J1
J2
J3
Q1
T4_2^(1/4)
T4_3^(1/4)[/CODE]
gave me the following outputs:
[CODE title="Scilab - output"]Q1 = -9656.9095
T4_2^(1/4) = 632.85074
T4_3^(1/4) = 589.11785[/CODE]
It's pretty close but there must be some mistake causing the difference. Do you know what can be wrong here? I'm specifically unsure about the areas (I assumed the depth of ##1 \ m##), absorptivities (I treated them as equal to emissivities) and formulas for view factors but other parts of the code may also be wrong.
Why are you so sure these are the correct results? Where do they come from?
You can always check the results by multiplying ##M## with ##x## which should give you back the right hand side ##R##. I get exactly the same results as you and I also get back ##R## if I do the multiplication.
The only thing that could be going on numerically is that if you have a large range of values in ##M## like here, you can get into trouble with significant digits. But then again, I don't really think that this is going on.
So it then must be in the modelling.
Here's the source of the correct results (pages 6-7): https://www.comsol.com/model/download/646601/models.heat.cavity_radiation.pdf
They are also confirmed by simulations.
That document doesn't include the details of analytical calculations so I had to figure them out using the referenced book by Bejan. It's likely that I made some mistake but it must be rather small since the outputs are pretty close to the expected values.
It turns out it contains all information needed, from page 7:
\begin{align}
Q_i &= L_i\frac{\varepsilon_i}{1-\varepsilon_i}(\sigma T_i^4 - J_i) \nonumber \\
Q_i &= L_i \sum_k F_{ik}(J_i - J_k) \nonumber \\
F_{ij} &= \frac{L_i + L_j - L_k}{2L_i} \nonumber
\end{align}
Note, that no ##\alpha##'s are needed here. So, for the second equation you get
Q_1 = L_1\left[F_{12}(J_1 -J_2) + F_{13}(J_1 -J_3)\right]
Etc...
This then results in the next matrix equation:
\begin{bmatrix}
-L_1(F_{12} + F_{13}) & L_1 F_{12} & L_1 F_{13} & 1 & 0 & 0 \\
L_2 F_{21} & -L_2(F_{21} + F_{23}) & L_2 F_{23} & 0 & 0 & 0 \\
L_3 F_{31} & L_3 F_{32} & -L_3 (F_{31} + F_{32}) & 0 & 0 & 0
\end{bmatrix}
\begin{bmatrix}
J_1 \\
J_2 \\
J_3 \\
Q_1 \\
T_2^4 \\
T_3^4
\end{bmatrix}
\begin{bmatrix}
c_1 \sigma T_1^4 \\
-Q_2 \\
-Q_3 \\
0 \\
-Q_2 \\
-Q_3
\end{bmatrix}
And in exactly the same way as before I now get the correct solution:
J1 = 4628.659
J2 = 8265.0226
J3 = 7083.2044
Q1 = -11000
T2 = 641.4362
T3 = 599.6912
[/CODE]
This solution actually makes much more sense since all fluxes add up to zero now ##Q_1 + Q_2 + Q_3 = 0##. I've checked this before but it didn't work out. I just thought I just didn't understand something about this problem. As I said, I don't know too much about radiation.
So in your first post, the equations for ##J_i## don't seem to fit this model. Also, ##\alpha##'s are not important because, since the cavity is enclosed, all radiation gets absorbed eventually.
@Arjan82 Thanks a lot again. So, to sum up, the system of 6 equations should look like this: $$Q_{1}= L_{1} \frac{\varepsilon_{1}}{1- \varepsilon_{1}}(\sigma T_{1}^4 - J_{1})$$ $$Q_{2}= L_{2} \frac{\varepsilon_{2}}{1- \varepsilon_{2}}(\sigma T_{2}^4 - J_{2})$$ $$Q_{3}= L_{3} \frac{\varepsilon_{3}}{1- \varepsilon_{3}}(\sigma T_{3}^4 - J_{3})$$ $$Q_{1} = L_{1} \left( F_{12} (J_{1} -J_{2}) + F_{13} (J_{1} -J_{3}) \right)$$ $$Q_{2} = L_{2} \left( F_{21} (J_{2} -J_{1}) + F_{23} (J_{2} -J_{3}) \right)$$ $$Q_{3} = L_{3} \left( F_{31} (J_{3} -J_{1}) + F_{32} (J_{3} -J_{2}) \right)$$ And the Scilab code is:
[CODE title="Scilab - fixed input"]L1 = 4;
L2 = 3;
L3 = 5;
eps1 = 0.4;
eps2 = 0.6;
eps3 = 0.8;
T1_4 = 307^4;
Q2 = 6000;
Q3 = 5000;
s = 5.67e-8;
c1 = L1*eps1/(1-eps1);
c2 = L2*eps2/(1-eps2);
c3 = L3*eps3/(1-eps3);
M = [
c1 0 0 1 0 0;
0 c2 0 0 -c2*s 0;
0 0 c3 0 0 -c3*s;
-L1*(F12+F13) L1*F12 L1*F13 1 0 0;
L2*F21 -L2*(F21+F23) L2*F23 0 0 0;
L3*F31 L3*F32 -L3*(F31+F32) 0 0 0
R = [
c1*s*T1_4;
-Q2
-Q3
-Q2
-Q3];
R
x = M \ R;
J1 = x(1);
J2 = x(2);
J3 = x(3);
Q1 = x(4);
T2_4 = x(5);
T3_4 = x(6);
J1
J2
J3
Q1
T2_4^(1/4)
T3_4^(1/4)[/CODE]
Now it also works in the other software in which I was trying to solve the initial, incorrect system of equations.
In fact, what confused me is this sentence from the referenced document:
Substituting this expression for the view factor into the second equation for the heat fluxes results in a linear system of six equations.
I thought that just the second equation for heat flux is needed to obtain the system of 6 equations and I was wondering how they did that so I reached for Bejan's book referenced by them and used the equations from it. Apparently, they are too general or not adjusted for this case.
So now I'm curious what other software you used to solve the equations :)
It's SMath Studio - free (but with some limitations like the limit of 3 devices per account introduced to new versions) equivalent of MathCAD. However, to solve this system of equations I had to use the Maxima plug-in for SMath. Maxima is open-source and truly free CAS software similar to Mathematica. It has its own GUI (wxMaxima) but SMath adds handling of units and a much more user-friendly display of formulas.
Unfortunately, I had to suppress the units for the equation since the software reported some inconsistency of units (there can be issues with temperatures sometimes).
