Trig Identity & Equations simplification
  • Thread starter Thread starter nursejason
    Identity Trig
The discussion focuses on simplifying trigonometric expressions using angle addition formulas. The first problem involves finding sin(pi/4 + x) given sin x = 1/3, with the solution derived through substitution and the Pythagorean identity. The second problem asks for cos(pi/4 + x) with sin x = -3/4, which also requires understanding the quadrant to determine the sign of cos(x). Participants emphasize the importance of using the correct formulas and understanding the relationships between sine and cosine. Overall, the conversation highlights the challenges of grasping trigonometric identities and the need for clear examples in educational materials.
nursejason
So I've tried to wrap my head around this concept, and I just read the last two sections in this chapter in order to really get a proper mindset here. Despite reading, there are no examples in the book that pertain to these questions, nor is there anything saying what kind of problem it is and as such I'm not able to look anything up.
Some problems are as follows :
Simplify the given expression :
A) If sin x = 1/3 and 0 < x < pi/2, then sin(pi/4 + x) = ?
The answer to this problem is 4+ sqrt 2 all over 6. And I have no idea how to get there. This section in the chapter mostly discusses sin(A+B) = SinASinB-CosACosB
B) If Sin x = -3/4 and 3pi/2 < x < 2pi then cos (pi/4 + x) = ?
Thanks in advance for your help.
If you don't know how to solve it, but at least know what I could look up to figure out how to get to this solution it would be much appreciated. Final is tomorrow and I'm trying to teach myself most of the concepts as my professor was pretty subpar this semester, and I'm not the best student!
Mathematics news on Phys.org
Hey nursejason and welcome to the forums.
For both problems you use the addition formulas for angles within trig functions.
So as an example for the first problem you're given sin(x) = 1/3. You are asked to find sin(x + pi/4).
You can simply use the fact that sin(x + y) = sin(x)cos(y) + cos(x)sin(y). By substituting x = the x you have and y = pi/4 we get
sin(x + pi/4) = sin(x)cos(pi/4) + cos(x)sin(pi/4)
Now given that [sin(x)]^2 + [cos(x)]^2 = 1 means cos(x) = SQRT(1 - [sin(x)^2) = SQRT( 1 - 1/9) = SQRT(8/9). But depending on the quadrant cos(x) will either be positive or negative, which we will come back to.
Ok so cos(x) = (+ or -) SQRT(8/9) = (+,-) 2/3 x SQRT(2). Plug this into your sin(x + pi/4) noting that sin(pi/4) = cos(pi/4) = 1/SQRT(2) we get
sin(x + pi/4) = 1/3 x 1/SQRT(2) + 2/3 x SQRT(2) x 1/SQRT(2)
= (3x1 + 3xSQRT(2)x2)/9xSQRT(2)
= (3 + 6SQRT(2)) / (9xSQRT(2))
= (1 + 2SQRT(2)) / 3SQRT(2)
Multiply this by SQRT(2)/SQRT(2) and you get
= SQRT(2)/SQRT(2) x (1 + 2SQRT(2))/(3xSQRT(2))
= (SQRT(2) + 4) / 6
Which is what the book gives.
If you're wondering about why I used + instead of -, look at the unit circle for the range which the angle is in. For example in 1st quadrant both are positive, but in 2nd cos is negative, 3rd sin negative and so on.
I may or may not be able to kiss you. I am a little lost at one part though, yet I understand most of the rest.
I lost you a little bit here. I am plugging in the +- 2/3 rt2 where exactly? I wrote this down and tried to figure it out a few ways but got a little lost.
Similarly I don't know how you got from the top line, to the one following. It's a lot more confusing than I would have imagined trying to convert keyboard text to what you're used to seeing in a text or on paper :P
Like I said, I understand the top line just fine. But I'm not sure how the rest flows.
Thanks so much for your help thus far!
You're substituting + 2/3 ROOT(2) for cos(x). That was figured out by using the fact that
sin^2(x) + cos^2(x) = 1. The + is because of the quadrant that x is in.
So I said that sin(x + pi/4) = sin(x)cos(pi/4) + cos(x)sin(pi/4)
sin(pi/4) = cos(pi/4) = 1/ROOT(2). sin(x) = 1/3, cos(x) = + 2/3 x ROOT(2)
Going from what I said above the rest is just collecting terms.
When I wrote a SQRT(2)/SQRT(2) all I did was multiply everything by 1 (which doesn't change anything). That basically gets rid of the square root on the denominator and when you collect all the terms together you get the answer.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
